Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056279
04/17/16 06:14 PM
04/17/16 06:14 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By The Sphinx
Brand new box
Had a brand new MSD box that didn't even make it out of the gate.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056442
04/17/16 11:22 PM
04/17/16 11:22 PM
HR3128 Offline
HR3128  Offline
Originally Posted By DARTH V8R
spark at the coil?
Only when I jumper the violet and green wires from the box side.
So The coil fires when you jump the violet & green wire. That proves your wiring & box are good. Next step is to verify the distributor will trigger the box.
Set-up the same test but leave the distributor violet & green wires connected. Pull the dist cap & rotor. Loosen the distributor hold-down so that you can turn the housing. Then rotate the housing so that the pick-up coil moves across one of the teeth on the trigger wheel. The MSD should fire the coil every time the pick-up moves across the trigger wheel.
If you position the dis pick-up & trigger wheel properly, you might be able to use the distributor advance to move the trigger back & forth across the pick-up. Coil should fire every time you do this.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058200
04/20/16 08:32 AM
04/20/16 08:32 AM
Champion City
The Sphinx Offline OP
Champion City
UPDATE:::::
I swapped in an MSD distributor and it fired right up. My best guess is there is not enough resistance in the factory distributors to trigger the box. Before the swap I ran my meter across the leads and read 525 ohms where the factory one read 287 ohms.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058309
04/20/16 12:16 PM
04/20/16 12:16 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Sounds like the pick up coil in the distributor was bad.
I ran my car for years with an OE distributor and a digital 6 box.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058503
04/20/16 04:43 PM
04/20/16 04:43 PM
Champion City
Champion City
But that distributor worked excellent in my other car. As its back in there and running.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058576
04/20/16 07:08 PM
04/20/16 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont know what to tell you.. I never ran a digital 6
but have run plenty of stock dist with 6al and 7al
boxes.. both lean burn and dist with timing... so I
would think that the digital box doesnt like something
about that dist.. might be the difference in the resistance
wave
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058583
04/20/16 07:29 PM
04/20/16 07:29 PM
Champion City
Champion City
Thanks for all the help everyone! 🚗 the old girls is running pretty good. I think my neighbors are already sick of my playing with the 2 step in the driveway.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2058644
04/20/16 09:29 PM
04/20/16 09:29 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Dunno man. Stock distributor should run with the digital 6 no problem. But hey, whatever works! Enjoy your ride laugh
