Re: Are all A body headers created equal?
[Re: 74RR]
#2056807
04/18/16 03:13 PM
04/18/16 03:13 PM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
The k frame changed in around '72 or '73 with the spool type setup. With this, the idler arm, center ink, and pitman arm are different. The idler and pitman face down on the later style.
This might be the reason???
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 74RR]
#2056867
04/18/16 03:55 PM
04/18/16 03:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ok, this is an engine swap, did you swap in a V8 k member or use conversion mounts, ala Schumacher?
Schumacher's mounts are two different heights and the taller of the two should be on the passenger side, which is the side you are having issues with.
If it's a factory V8 k member then look at the rubber bushing on the pass side mount and make sure it isn't collapsed.
[Re: 74RR]
#2057043
04/18/16 06:48 PM
04/18/16 06:48 PM
Supercuda
About to go away
About to go away
up yours
Did you cut down the driver's side as required? If not that wouold rotate the engine towards the pass side possibly being the issue?
[Re: 74RR]
#2057099
04/18/16 07:55 PM
04/18/16 07:55 PM
Supercuda
About to go away
About to go away
up yours
Unless the header are not what is claimed. Did you look at the pictures of Hooker Headers at Summit and see if they match what you have?
Only other thing I can think of. They make a couple of different types that will bolt to the small block, but not fit the chassis.
