I have a new question, but it is a bit hard to explain in english.
On the very top of the TQ there ist that little screw for adjusting the metering rods.
over that screw there is normally that little metal thing with a hole in it so that you can reach the screw.
That thing is broken on my carburetor. the top part is missing (broken off). but the lower part of it exists and was holding down that whole metering rod part.
So two questions:
- Is that okay.
- was it right, that it was holding down the metering rods?
EDIT:
I forgot to ask about the buckets under the main wells.
The sealing material is normally oozing out (is that the right word). On my TQ it is not at some areas, because it broke off (it is really hard).
Should I reseal them? And if so, can I just rip em apart?
EDIT 2:
I just looked at some pictures and videos and all of them had the screw for the metering rods a the same level as the top of the piston. Mine was a fair bit over it (leaner?).
I know that my TQ never was adjusted right and all, that's why I am rebuilding it.
But that is a bit strange.
