Page 2 of 3 1 2 3
Re: big block with factory heads how fast can i go? [Re: Thumperdart] #205547
01/27/09 03:42 PM
01/27/09 03:42 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
AL
What was your combo, cam, compression, etc.
Was it the purple Duster?.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: big block with factory heads how fast can i go? [Re: moparmafia] #205548
01/27/09 04:27 PM
01/27/09 04:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest, your 5.99 in the 1/8 is a 9.40 pass
and figureing 3200 lbs thats gonna take 720 hp
and to get that 720 hp you need right about 320 cfm
head flow.... I dont think you can get that from a
stock head
Re: big block with factory heads how fast can i go? [Re: moparmafia] #205549
01/27/09 04:31 PM
01/27/09 04:31 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
First off let me state this for those who are not clear on this point a 5.99 in the 1/8th will be low 9.40's in the 1/4.
While I am quite sure it can be done my first question would be WHY? You are gonna need something north of 700hp and getting that from a set of factory iron heads will require a lot of money being thrown at them. The amount of money you will have to spend to achieve this woudl be better spent on better parts. I have gone 9.60's at 3050 with a set of iron heads, but I had enough can in it to go Comp racing Only so much you can get from a factory type head, so you are gonna have to make the motor think you got more by using a TON of cam. Now throw in a power adder and at least you can keep the dollar amount spent at a sane level for the return.
its just one of those things i have always wanted to try. i really dont see it being the most expensive build i have done. i already have 2 sets of 906 heads fully ported. i have built 2 500 inch indy motors in the past and i cant see it costing near that but i could be wrong. most of my friends all run either ford or chevy and they have always laughed and said mopar has the ugliest and slowest cars. i guess its crazy to try and max out a factory combo but its just a personal thing now.
you say you have the heads , build it and let us know how it works out ...
Re: big block with factory heads how fast can i go? [Re: MR_P_BODY] #205550
01/27/09 04:34 PM
01/27/09 04:34 PM
AndyF Offline
AndyF  Offline
I think it is possible to get 320 from factory iron heads but you have to do a lot of work. Probably cost $5000 by the time you're done to get a good set of heads that would flow those numbers. Dwayne might know, he might have worked on a project like that before.
I haven't seen any of the current 906 heads used for Super Stock racing but I'd imagine they flow numbers like that. I bet they cost a ton of money and don't last long either.
Re: big block with factory heads how fast can i go? [Re: MR_P_BODY] #205551
01/27/09 04:40 PM
01/27/09 04:40 PM
Ky
moparmafia Offline OP
Ky
stock head
you are probably right about the 320 head flow. i have never seen a factory head flow that much. we had a set here that flowed 305 but i dont think you could have gotten 1 more cfm out of it. but i had a 70 dart that weighed 3310 that had a 400 stroked to 500. it had mild 906 heads that flowed 256 and a comp .650. that car had spinning/ chassis problems like you wouldnt believe. i only made 4 passes and it went 6.59. it was nowhere near maxxed out and would have been 2-3 tenths quicker by hooking it. everyone said those heads were going to choke it to death til they seen it run. thats what got me to thinking maybe its possible to run the 5.99 with factory heads
Re: big block with factory heads how fast can i go? [Re: moparmafia] #205552
01/27/09 04:47 PM
01/27/09 04:47 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Most of the chevy and ford guys I know are running stroker motors with big aluminum heads. You would be handicapping yourself bigtime but you could do it if you are just talking an 1/8 mile.
Port the crap out of some late 452's and throw some big tires and a ton of cam and gear in the car and go run your 5.99.
Re: big block with factory heads how fast can i go? [Re: moparmanjames] #205553
01/27/09 05:50 PM
01/27/09 05:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
wouldn't max wedge heads be considered "factory" heads? i would think they would be a better starting point than a 906, 452 or 915 casting. to each his own but can't see the reasoning on this one. pound for pound a stock mopar wedge head just plain sux compared to what chevy and ford have had available...face it they just had better heads. if you only picked up a tenth after swapping from a set of 452's to a set of -1's i'd be looking for the plug wire(s) that fell off
Re: big block with factory heads how fast can i go? [Re: jamesc] #205554
01/27/09 06:31 PM
01/27/09 06:31 PM
Ky
Ky
fell off
then honestly i dont think you realize the potential of the mopar factory big block heads. i totally disagree that chevy and ford were better. this chevy way of thinking is my whole point in doing this. it would make me feel good to prove people like this wrong and show them pure mopar power.
Re: big block with factory heads how fast can i go? [Re: moparmafia] #205555
01/27/09 07:12 PM
01/27/09 07:12 PM
You are dreaming if you think a factory 906 or 952 ported headed 440 in a big 70 GTX will run 5.90's maybe 6.70-6.80 with a good suspension..
Re: big block with factory heads how fast can i go? #205556
01/27/09 07:41 PM
01/27/09 07:41 PM
tennessee
mike54 Offline
mike54  Offline
tennessee
how much power to go 5.99?..well last time i saw bob reeds ss/ah stick car run at mooresville , he ran a 5.81..it was a full out run..just over 3,000 pounds, a scienced out suspension, and a big tire. im sure of the readers here can give us a power estimate of bob's hemi
Re: big block with factory heads how fast can i go? [Re: moparmafia] #205557
01/27/09 10:12 PM
01/27/09 10:12 PM
jamesc Offline
jamesc  Offline
i drive a 01 dodge dakota, 97 dodge ram cummins, 72 383 dodge dart, 225" s&w with a 451, 245" Mike Boz that i'm building a 557" b1 headed KB block plus 470" and 448" mills sitting under the bench so you need not fear i have a "chevy way of thinking". if you believe the stock chrysler castings are so great have at it...i'll stick with my aftermarket junk.
Re: big block with factory heads how fast can i go? [Re: mike54] #205558
01/27/09 10:26 PM
01/27/09 10:26 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
From what I have been thru in the past, the money spent on a maxed out Iron Head will get you a set of 440-EZ-1 Indy's. A really leaned on Iron Head is prone to cracking. You can cut an Indy in 1/2 and still be able to save it. Cracked Iron Heads are good for fishing and planting flowers in. I run a set of the EZ-1's in my old beat up barf-a-cuda. I run 500 inches with a .590 comp cam, 4150 base carb, 4.30 gear, and 9.0 X 30.0 slick that hooks at any track. (besides this year at the Norwalk CC Event @ 2:00 am in the rain) This thing does not see over 6700 rpm. Best 1/4 mile so far 10.13 @ 129.98. The car is 3180 lbs with me in it. The rear springs have about 900 passes on them. With a Cam, Carb, and Gears I could run the #'s you are looking for. We are bracket racing correct? It is NOT how fast you can go, It is HOW LONG YOU CAN GO FAST. Save the Iron Heads for the resto guys.
Re: big block with factory heads how fast can i go? [Re: cudasteve68] #205559
01/27/09 11:28 PM
01/27/09 11:28 PM
gregsdart Offline
gregsdart  Offline
Most of the responses here say save the money and go aftermarket heads. I agree to a point. You can run what you have and ring the most out of them with a tunnelram and big roller, and if you do it right with a very efficient oilpan to reduce windage, and very well designed piston and ring package I think its possible at a sealevel track. It will be on the edge though!
I would set the shortblock up with a zero deck to allow the move to either Indy SR or 440-1 heads to pick up the pace at a later date and replace those crack prone 906s.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: big block with factory heads how fast can i go? [Re: gregsdart] #205560
01/28/09 12:13 AM
01/28/09 12:13 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i had a 448 with 906's and a tr with 2-660's, flat tappet cam that went 6.16, but that was at about 2825#. i believe we had one of the best set of 906's anywhere. with all due respect, to run those numbers anywhere but at a killer track and with density alt. air below sea level in a 70gtx weighing 3200 {is that with or without driver?} IS VERY UNLIKELY. i believe you said you wanted an engine that would stay together........ i don't think it will happen,sorry. maybe 6.40 to 6.70
Re: big block with factory heads how fast can i go? [Re: tjmarcus1] #205561
01/28/09 12:46 AM
01/28/09 12:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well you asked how fast you can go. I thought I stated earlier but here goes. My old iron headed deal ran well at a best of 9.69, but that was at ONLY 136 mph. I did manage a best of 6.15 but that was at 3050 lbs. The car worked very well, particularly in the first 330', it never mile per houred at all. In that sense it was more like a Super Stocker than the average bracket car. Heck it went low 1.30 60's always and managed a 1.28 best. My Barracuda is not much better in the 60' at 1.5+ seconds faster.
I understand the why of proving a point. Lord knows I have done similar stuff a few times. I built my iron headed deal to prove a point in a way, that you dont need aftermarket aluminum heads to run 9's in a typical back half bracket bomber.
I had a 480" BB with a stock steel 4" stroke crank, inexpensive aluminum rods and shelf Ross pistons(13-1). If I recall the heads were just shy of 270 cfm. The cam was large by huge. I dont have the cam card any longer as I sold the car but it was in excess of .850" lift and the duration was in the upper 280's at .050" It used a set of springs up a season. I had to lash the valves pretty much all the time but I like to work on stuff so it did not bother me. The first thing the new owner did was loose the cam and the car responded by slowing down a bunch, to a 10.teen car.
My point is I have been there done that. Thought I made that point earlier. Can you go 5.99 at 3200 pounds on leafs with no power adder and iron heads....I will say NO, but what do I know. IF you can it will be a very costly venture. Feel free to prove me wrong, as stated I will be the first in line to congratulate you.
BTW the guy who pointed out the SS/AH stuff is apple to oranges. Do you really think you can compare a set of AH prepped Hemi heads to an iron ported wedge head? Are you also saying a 3200lb stock suspension(leafs)car can compare to prepped Super Stocker? Hello!!!!
FWIW here is my turd that had the iron heads and ran ok...
Re: big block with factory heads how fast can i go? [Re: Al_Alguire] #205562
01/28/09 03:59 AM
01/28/09 03:59 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
8.14...180ish. 3000# prostock Dart. DLI built 500 inch w/ stage 4 heads. Hemi block. See the post about Dick's Dart, Lenco and all. I sold the motor back but had about 1150 hp. All of Dicks secrets in it. Built in 1979. Today at least $30k to build.
Re: big block with factory heads how fast can i go? [Re: HUSTLESTUFF] #205563
01/28/09 07:46 AM
01/28/09 07:46 AM
Sparta, TN
mark42202 Offline
mark42202  Offline
Sparta, TN
I run a stock bore, stock stroke 440 with 915 heads, .520 lift cam, launch at 2900 off the foot brake, shifting at 5700rpm with 4.30 gear and run 6.70's in my 64 Fury at 4000ft d/a on alky. It weighs 3420 with me in it and a full fuel cell. I think it can be done if you put the money in the right spots. I say go for it!
Re: big block with factory heads how fast can i go? [Re: mark42202] #205564
01/28/09 09:42 AM
01/28/09 09:42 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'm not saying one way or the other but, doesn't
Don Little run a 383 in his 70 Challenger?
Currently 9.70 @ 136.20 in GT/FA (S/S)
Factory heads and carburetor
Re: big block with factory heads how fast can i go? [Re: S/ST 3040] #205565
01/28/09 10:26 AM
01/28/09 10:26 AM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
This may be true but to reiterate Al's point, How much is Don Little gonna sell you a set of those heads for? And it's not just those heads that makes that car run those numbers.Those guys do things to those cars we can't imagine,thats why they are so impressive.I have seen some stock eliminator pieces being made that would blow your mind for a hundredth or two gain.Those guys are nuts ,IMO.
Re: big block with factory heads how fast can i go? [Re: BEEQUIK] #205566
01/28/09 10:49 AM
01/28/09 10:49 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
With enough money, work and dedication I think its possible. I guess the next question would be, are you the man for the job?
Getting old just means you were smarter than some and luckier than others.
Page 2 of 3 1 2 3
