Re: Car Wiring.........
[Re: Monte_Smith]
#2052907
04/12/16 05:03 PM
04/12/16 05:03 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Monte,would having an 8ga wire off the negative battery post to the body cause noise with everything BUT the lights grounded through a buss bar?
Mopar to the bone!!!
[Re: JERICOGTX]
#2052931
04/12/16 05:48 PM
04/12/16 05:48 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The biggest problem with most people wiring a car themselves is, they think zip ties are expensive...
Nice work Monte.
Jeff Cut em off.......put em on........LOL!!!! I go through enough zip ties wiring a car to do 3 harnesses. I bundle as I go to keep things tight. Then you ad wires, rearrange, whatever, you cut them off and redo. I never just add more ties. I buy the small ones by bags of a 1000
[Re: Monte_Smith]
#2052939
04/12/16 05:59 PM
04/12/16 05:59 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Cool! I use the exact same bus bar and ARC switch panel! I read your posts about grounding both heads and everything else to the bus bar and wired it up that way. Thanks for the info! ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
[Re: RylisPro]
#2052949
04/12/16 06:20 PM
04/12/16 06:20 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Cool! I use the exact same bus bar and ARC switch panel! I read your posts about grounding both heads and everything else to the bus bar and wired it up that way. Thanks for the info! How was the install on the ARC panel? Really thinking about one of those
[Re: RylisPro]
#2052950
04/12/16 06:21 PM
04/12/16 06:21 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Great post Monte and very nice work. Found a 10% off coupon from Summit last night so I am filling my cart and found this one. http://www.summitracing.com/parts/rfw-gw15/overview/
[Re: cagebob1]
#2052991
04/12/16 07:27 PM
04/12/16 07:27 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
not trying to hi-jack, but is there a proper orientation to a relay? As in right side up? I thought I read somewhere that the g forces of a drag car could cause the contacts to open under acceleration. I could see how the contacts may bounce in the non-energized position, but the magnetic force of the energized position should maintain that position? From the spec sheet I found (posted below) you would need 30g force non-energized? Mounting position may have more to do with keeping moisture out of the assembly? If you are worried, there are solid state replacements for the relay. http://www.delcity.net/store/Hella-Solid...CFQ-oaQodtt0NZAI found this data sheet: http://www.mouser.com/ds/2/418/NG_DS_V23134-X0000-A002_0315-572885.pdfShock resistance (functional) IEC 60068-2-27 (half sine) 6ms, min. 30g.8) Note: 8) No change in the switching state >1μs. Valid for NC contacts, NO contact values significantly higher.
[Re: JERICOGTX]
#2053021
04/12/16 08:16 PM
04/12/16 08:16 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The Thomas and Betts that I use are about $.35~$.80 each The biggest problem with most people wiring a car themselves is, they think zip ties are expensive...
Nice work Monte.
Jeff
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: pittsburghracer]
#2053026
04/12/16 08:19 PM
04/12/16 08:19 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
If you have the wire you could save some money by purchasing from a marine supply. I paid $14 buck for the same one.
[Re: rowin4]
#2053279
04/13/16 12:32 AM
04/13/16 12:32 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Several ideas here that need to be thought about.
Read sfi spec you can have holes in tubes. The size of the hole depends on the diameter of tube. Mike, Monte's within rules.
There are many approaches to grounding. Floating grounds have their place and most of the time the term is misused. Many in the real electronic industry have different ideas. We used floating grounds in radio and tv. You have to isolate with test equipment. In the home ground requirements change every year.
If your negative battery bus is not tied to chassis it is not ground. Ground is related to earth ground and is made theough carbon in rubber tires. I could see where there may be benefits to using an isolated negative. This way no current is traveling through chassis. The main rail the crank trigger wire is in is a non current carrying ground, well actually if chrome moly a resister. Pretty slick, if you understand why you did it.
I have a huge disagreement with the railroad industry, where I work. They ground everything. Then spend millions on lightning protection. Because lightning looks for ground. But, when you got two huge conducters running for miles at ground potential, and you use it for signaling, you really have little choice.
Some day I plan a total rewire. I just don't like anyones stuff sold to wire cars. The people who do this have a limited electronic knowledge. I don't have the time or energy to do this the way I think it should be done. Some are nicer than others. None would hold up in the rail industry due to vibration. Oh wait race cars vibrate all the time.
Nice clean work Monte. I look at anybodies wiring and take issue, including my own. When you do this 24/7 and the public depends on it. You'd better be right. Always looking for a better way.
[Re: Monte_Smith]
#2053414
04/13/16 05:53 AM
04/13/16 05:53 AM
Posts: 234 Brisvegas, Australia
Alchemi
Looks awesome Monte I think how you have done the earthing is also referred as a "star" earthing system, they do this in music studios for the whole RF thing A couple of months ago I found this following a link from a link.... https://www.rbracing-rsr.com/wiring_ecu.htmlHoley crap!!! $25k wiring job for your salt racer, wow. They seem to know their stuff though and if anyone can make it all the way through the (very long) page, the average joe on here would learn a thing or five from it ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: moparx]
#2053482
04/13/16 09:53 AM
04/13/16 09:53 AM
Posts: 10,050 MN
JERICOGTX
MN
Your best friend when it comes to zip ties.
69 GTX
68 Road Runner
[Re: DemonDust]
#2053555
04/13/16 11:55 AM
04/13/16 11:55 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
The good ones aren't exactly cheap! haha
I have thousands lol White zip ties are for tying up the bag of shop garbage. If you can find them (Fastenal, etc.) we prefer metal barbed, black UV resistant zip ties. Also, a "flush cut" dykes/diagonal cutter (Knipex is my favorite) is a must for getting the tails of the zip ties cut flush with the cinch end to avoid sharp ends. Weatherpak connectors, buss bars, and weatherproof labeling will make your life much easier.
[Re: Jeremiah]
#2053559
04/13/16 12:05 PM
04/13/16 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have that zip tie tool also.. I wish I would use it more often.. those SHARP cuts sure will cut you up.. my hands right now have about 15 small cuts from those zip tie ends(from doing the MSD box)... 99% of the ties I use are the black UV ones.. I have bags of zip ties of assorted sizes ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: moparx]
#2053564
04/13/16 12:11 PM
04/13/16 12:11 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
so does the ground bus get tied to the chassis at some point, or does one run a ground from the body/chassis at the battery - then another cable to the ground bus ? i like to use a bus whenever possible, but i have experience only on the "+" bus installation. the next complete job i would like to employ both. monty, please clarify. thanks ! It never gets grounded to chassis.
Brett Miller W9 cnc'd heads STR Chassis fabraction
