Re: motor plate water pump gasket problems [Re: 440Jim] #2052614
04/12/16 09:52 AM
04/12/16 09:52 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Originally Posted By 440Jim
Although I had a one piece front plate, I found that after awhile (months) gaskets could leak. Then I just used only RTV (no gaskets) and it never leaked again.
Same here. We have actually replaced most every gasket on our engine with RTV.
Re: motor plate water pump gasket problems [Re: challengermike] #2052618
04/12/16 10:12 AM
04/12/16 10:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted By challengermike
Originally Posted By jughed
Never had a leak (1 piece plate) when sealed with Hylomar. And there is no cure time.
Is that like the stuff gm use's on the front diff case half and t case half ? There's is red though.
No that is aenerobic sealer. Poor in shear, very brittle when it cures. Works great for a small gap surface.
Doug
Re: motor plate water pump gasket problems [Re: challengermike] #2052620
04/12/16 10:17 AM
04/12/16 10:17 AM
an8sec70cuda Offline
I just use ultra grey silicone, no gaskets. No leaks in 10 years.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: motor plate water pump gasket problems [Re: challengermike] #2052627
04/12/16 10:30 AM
04/12/16 10:30 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As many have mentioned,use RTV silicone(ultra black/ultra grey) let cure 100% before final torque.
Re: motor plate water pump gasket problems [Re: challengermike] #2052628
04/12/16 10:30 AM
04/12/16 10:30 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I had the two piece deal like you have. I just bought AndyF's single piece motor plate. It arrived yesterday. Man is it nice. Hughes engines had best price I found.
eBay-cdwmotorsports
Re: motor plate water pump gasket problems [Re: challengermike] #2052631
04/12/16 10:34 AM
04/12/16 10:34 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
THICk one piece and Superperfomance gaskets and no more leaks!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: motor plate water pump gasket problems [Re: challengermike] #2052783
04/12/16 02:40 PM
04/12/16 02:40 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Years ago I ran the 2 piece ear mounts, flex would break the seal and it would start to leak. I welded a strap across the top of the ears and that stopped the flex and the leak problem. Now I have AndyF front motor mounts on 2 of my cars, I just use standard water pump gaskets and never have had a leak. I do put stress on them from torque to pounding the oil pan into the pavement.
