Testing a stock distributor. #2052588
04/12/16 07:11 AM
04/12/16 07:11 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
My Crane HI6 is telling me it's not running because it's lost its trigger signal. How do you test a stock style (read Summit special) distributor trigger signal?.
Re: Testing a stock distributor. [Re: rebel] #2052590
04/12/16 07:30 AM
04/12/16 07:30 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
ossilliscope
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Testing a stock distributor. [Re: rebel] #2052610
04/12/16 09:33 AM
04/12/16 09:33 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Use an ohm meter to check the pick up. I just checked a known working one. It reads .320 ohms on the 20K scale. This reading is with the dist un plugged, engine at a stand still.
If you get infinite resistance(no reading) or no resistance (shorted) it's bad.
Re: Testing a stock distributor. [Re: rebel] #2052657
04/12/16 11:36 AM
04/12/16 11:36 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah, just check resistance across the plug for the pickup coil.
something like 300-600 ohms is the spec.
if the airgap is too large it won't signal either.
that spec is around .008-.015
