Re: motor plate water pump gasket problems
[Re: 440Jim]
#2052614
04/12/16 09:52 AM
04/12/16 09:52 AM
Posts: 2,584 S.E. Michigan
cl440
S.E. Michigan
Although I had a one piece front plate, I found that after awhile (months) gaskets could leak. Then I just used only RTV (no gaskets) and it never leaked again. Same here. We have actually replaced most every gasket on our engine with RTV.
[Re: challengermike]
#2052618
04/12/16 10:12 AM
04/12/16 10:12 AM
Posts: 9,982 MI, usa
dvw
MI, usa
Never had a leak (1 piece plate) when sealed with Hylomar. And there is no cure time. Is that like the stuff gm use's on the front diff case half and t case half ? There's is red though. No that is aenerobic sealer. Poor in shear, very brittle when it cures. Works great for a small gap surface. Doug
#2052620
04/12/16 10:17 AM
04/12/16 10:17 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I just use ultra grey silicone, no gaskets. No leaks in 10 years.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
#2052628
04/12/16 10:30 AM
04/12/16 10:30 AM
Posts: 1,517 Martinsville, IN
cdwmotorsports
Martinsville, IN
I had the two piece deal like you have. I just bought AndyF's single piece motor plate. It arrived yesterday. Man is it nice. Hughes engines had best price I found.
eBay-cdwmotorsports
#2052783
04/12/16 02:40 PM
04/12/16 02:40 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Years ago I ran the 2 piece ear mounts, flex would break the seal and it would start to leak. I welded a strap across the top of the ears and that stopped the flex and the leak problem. Now I have AndyF front motor mounts on 2 of my cars, I just use standard water pump gaskets and never have had a leak. I do put stress on them from torque to pounding the oil pan into the pavement.
