Re: 727 Leaking !!
[Re: okie]
#2051829
04/11/16 01:51 PM
04/11/16 01:51 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Is it just the one seal? There's not one on the center rod ? I"m going to see if I can get what I need today. Thanks Ronnie Yes there is a seal in the center , that one is a little harder to replace in the car but it can be done, but that seal is above the full level so it should not cause the bad leak you say you have.
Mainstream Media is the new Pravda
Re: 727 Leaking !!
[Re: okie]
#2051953
04/11/16 04:34 PM
04/11/16 04:34 PM
Posts: 632 Zombieland
Car Nut
Zombieland
Is it just the one seal? There's not one on the center rod ? I"m going to see if I can get what I need today. Thanks Ronnie Yes. but that seal is above the full level so it should not cause the bad leak you say you have. Will leak when the torque converter drains back.
Re: 727 Leaking !!
[Re: okie]
#2053546
04/13/16 11:38 AM
04/13/16 11:38 AM
Posts: 3,017 Sac, CA
mopowers
Sac, CA
Napa # ATP13308 is the part number for the throttle pressure shaft seal.
Re: 727 Leaking !!
[Re: okie]
#2053797
04/13/16 06:54 PM
04/13/16 06:54 PM
Posts: 12,314 Looking for a way out of Middl...
IMGTX
Can I change this one with the tranny still in the car like the big one There is a small snap ring that holds the two shafts together on top. Remove it then the seal. The problem is that when you remove it, it will want to let the shaft fall down into the case and the pan may need to come off. IIRC but it's been a little while
