Page 2 of 4 1 2 3 4
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2049848
04/08/16 05:04 PM
04/08/16 05:04 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted By pittsburghracer
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore
Agreed , taking anything off the cap could change the hole in the cap/block
Mainstream Media is the new Pravda
Re: Billet Main Cap Question, Part 2 [Re: JohnRR] #2049859
04/08/16 05:17 PM
04/08/16 05:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And John your the one that split a block... 2 hits
with a file on both sides isnt gonna change DICK
and you guys are acting like this is rocket science
and its not.. I've seen plenty of machine shops do a
ton of stuff that some wouldnt do and they turned them
9000 rpm and .... they lived a long time
wave
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2049867
04/08/16 05:32 PM
04/08/16 05:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
At Pettis it was common practice to hit the main saddles w/a fine file.......
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2049872
04/08/16 05:39 PM
04/08/16 05:39 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By MR_P_BODY
2 hits with a file on both sides isnt gonna change DICK
and its not..
My new favorite quote! wave
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Billet Main Cap Question, Part 2 [Re: Thumperdart] #2049874
04/08/16 05:41 PM
04/08/16 05:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've seen it done many times even after the bore
was done.. because they had to much of a problem
getting the caps on
wave
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2049880
04/08/16 05:49 PM
04/08/16 05:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
wave
Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2049894
04/08/16 06:11 PM
04/08/16 06:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
It might last some a life time... I tend to spin
them up even stock blocks... LOL and I was in the
8s with my junk
wave
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049899
04/08/16 06:21 PM
04/08/16 06:21 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Smoke em with an angle grinder and you'll be able to throw them on from a couple of yards.
No issues installing or removing them
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049914
04/08/16 06:52 PM
04/08/16 06:52 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Put the main Capps in your freezer over night, and let the block sit in the sun....
Re: Billet Main Cap Question, Part 2 [Re: boatracer572] #2049929
04/08/16 07:14 PM
04/08/16 07:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... but most dont do that... IF they are lucky
they do the work at room temp.. I had a guy teaching
me on machining that came from NASA.. it told me that
5* was the limit for there work.. then it went back into
a temp controlled room... so that junk took for ever to
machine(with a ton of cutting fluid on the part)
wave
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2049941
04/08/16 07:37 PM
04/08/16 07:37 PM
PA.
"Little"John
"Little"John
PA.
Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL [/quote]
8s with my junk
wave [/quote]
Not picking here but did you ever run a stock big block? And how long ago?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2049948
04/08/16 07:42 PM
04/08/16 07:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
8s with my junk
wave [/quote]
Not picking here but did you ever run a stock big block? And how long ago? [/quote]
Back when I ran a destroke 383.. big rpm engine
then a couple of years ago I bought a mega, new
Callies crank, and B1m/c heads.. but I ended up
selling all that stuff.. again that was gonna be
high rpm (9000+)
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049977
04/08/16 08:23 PM
04/08/16 08:23 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Watch what this guy does at 4 mins into this clip.
https://www.youtube.com/watch?v=e3r3wRBoXkk
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2049998
04/08/16 09:06 PM
04/08/16 09:06 PM
The last KB aluminum block I worked on had steel main caps, isn't that thier stock standards now work I'm almost postive that all the after market race hemi aluminum blocks some with the main caps tap for using a slide hammer to remove the main caps work
Re: Billet Main Cap Question, Part 2 [Re: deaks] #2050006
04/08/16 09:17 PM
04/08/16 09:17 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Ya he deburrs the block before the line hone on a chev.
And the point is you need to know how to machine a chev??
Re: Billet Main Cap Question, Part 2 [Re: The Shadow] #2050240
04/09/16 09:59 AM
04/09/16 09:59 AM
moparx Offline
moparx  Offline
i am no engine builder, although i have assembled quite a few over the years, all makes[even an import] and sizes. it looks like the OP is using bolts, thus having difficulty starting the caps square. in situations i have encountered over the years when mating of parts together must be square, i cut alignment dowels from a couple of old bolts and thread them into the holes, mate the parts together, then remove the alignment bolts and replace with the intended fasteners. this may be something the OP would want to consider. just something i would try before going to more drastic measures. your results may vary....
beer
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2050453
04/09/16 04:01 PM
04/09/16 04:01 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Can you measure and see what interence is? I'd try chilling them first and heating the block. If it's to much of an interence fit then carefully flat filing each side and carefully measuring to make sure you take an equal amount of each side would be okay.
What kind of an interference do caps usually have with the block? .002"?
Re: Billet Main Cap Question, Part 2 [Re: WO23Coronet] #2050463
04/09/16 04:18 PM
04/09/16 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Closer to .001... at .002 your gonna need a press
wave
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2050596
04/09/16 08:16 PM
04/09/16 08:16 PM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
II have .02 difference between the cap and the block. The caps are in the freezer and I am going to check again in a while.
I really appreciate all of the good advice and information from everyone!
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2050601
04/09/16 08:21 PM
04/09/16 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.020 is huge... you might mean .002.. and thats tight
wave
Page 2 of 4 1 2 3 4
