Re: Who makes their own brake lines??
[Re: DaytonaTurbo]
#204923
01/26/09 03:53 PM
01/26/09 03:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Practice the flaring on a couple spare lengths of lines. You don't want to have to cut and shorten a perfectly bent line you spent hours perfectly. ![](/ubbthreads/images/graemlins/whistling.gif) Yes the stuff at NAPA will work fine
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#204925
01/26/09 04:54 PM
01/26/09 04:54 PM
RapidRobert
I'd buy several of the prefabbed lenghts of brake line at your parts house that are already flared w a sliding fitting on each end & with several of the double female brass connectors I've rarely had to cut one &(double) flare it & 3/16 brake line you can bend it by hand without a bender with care just dont make too tight of a radius & if you have to then use the bender. If you do have to cut/flare as said practice on a few pieces of scrap line, your old ones for instance. These inverted flare fittings seal at the flare(as you know) rather than the threads like NPT so you want the flare to be good. Make the flare dia the same size as the cone on the inside that it is going to seat against, not larger,not smaller with a smooth surface thats why a few practice attempts is a good idea.
[Re: RapidRobert]
#204926
01/26/09 05:06 PM
01/26/09 05:06 PM
Posts: 173 Tucson AZ
2cudabuck
Tucson AZ
I did mine on my road race car, with just a summit tubing kit. But ![](/ubbthreads/images/graemlins/iagree.gif) , if someone can help him measure the actual route of the lines, and get pre-flared lines to bend into place, I would think that would be the way to go.
Buck
67 273 Dart GT
69 RT 440 Charger (SWEET!)
70 318 Cuda
74 Cuda Packin a 426 roller Hemi
[Re: 2cudabuck]
#204927
01/26/09 05:21 PM
01/26/09 05:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you do it with the coated lines be sure to clean the coating off of the area that will form the flare. I've seen lines leak at the fittings because of this.
#204928
01/26/09 11:32 PM
01/26/09 11:32 PM
Posts: 857 charlotte,nc
pyp1000
charlotte,nc
Don't ask me how I know.
If I can bend my own brake lines. Anyone can.
[Re: JDMopar]
#204930
01/27/09 08:37 AM
01/27/09 08:37 AM
Posts: 1,443 Maryland
Dads426
Maryland
There is a guy on ebay selling a preflared brakeline assortment ranging in length from 6" to 50" for about $50 delivered. With the exception of the front/rear line, I was able to fabricate all of the rest of the lines using this kit. I hate flaring, so this kit was worth it. See: chrysleroldtimeparts. Since the lengths are fixed, use a coat hanger or bailing wire of the same length and fit it to the application before bending the line.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Mr.Yuck]
#204932
01/27/09 09:44 AM
01/27/09 09:44 AM
Posts: 5,337 the house on the left.
cogen80
Any parts store will have decent line you can bend. Make sure you get the double flair right....
i agree. they are easy to make.
[Re: prochargedhemi]
#204936
01/27/09 03:51 PM
01/27/09 03:51 PM
Posts: 146 michigan
tonycpe
michigan
i agree , good idea to debur.
Also the quality of the flair tool can make a difference in the finished flair.
I wore out my 30 year old one recently and had to buy 4 of them in order to find one that flaired properley
And it ended up being the cheapest one.
Old Fogey Racing Ltd.
