Who makes their own brake lines?? #204922
01/26/09 03:35 PM
01/26/09 03:35 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
My dad's fixing up his 83 Rampage and the steel brake lines that run from the master cylinder to the rear brakes are shot. Repops are non-existant so he'll have to make some. I've got a summit brand double flaring kit he can borrow but I've never tried it on brakes, highest pressure I've ever done is some lines for an efi fuel system.
Anything special he needs to know before going out and buying his line and fittings and pulling out my tube bender? Do brake lines just use regular steel tubing like the stuff you can buy at Napa? Hopefully they or someone else in town can supply the correct fittings as well. Any tips or tricks to pass along?
Re: Who makes their own brake lines?? [Re: DaytonaTurbo] #204923
01/26/09 03:53 PM
01/26/09 03:53 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Practice the flaring on a couple spare lengths of lines. You don't want to have to cut and shorten a perfectly bent line you spent hours perfectly.
Yes the stuff at NAPA will work fine
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Who makes their own brake lines?? [Re: HealthServices] #204924
01/26/09 04:41 PM
01/26/09 04:41 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I just did mine on my dart. Cheap ole Harbor Frieght double flaring tool. I used brake lines from Advance Auto, that have "armor coating" on the outside. Basically just painted.
Worked great and looks great.....no tricks! I just bleed them and no leaks or pressure breakdowns at all.
Re: Who makes their own brake lines?? [Re: HealthServices] #204925
01/26/09 04:54 PM
01/26/09 04:54 PM
I'd buy several of the prefabbed lenghts of brake line at your parts house that are already flared w a sliding fitting on each end & with several of the double female brass connectors I've rarely had to cut one &(double) flare it & 3/16 brake line you can bend it by hand without a bender with care just dont make too tight of a radius & if you have to then use the bender. If you do have to cut/flare as said practice on a few pieces of scrap line, your old ones for instance. These inverted flare fittings seal at the flare(as you know) rather than the threads like NPT so you want the flare to be good. Make the flare dia the same size as the cone on the inside that it is going to seat against, not larger,not smaller with a smooth surface thats why a few practice attempts is a good idea.
Re: Who makes their own brake lines?? [Re: RapidRobert] #204926
01/26/09 05:06 PM
01/26/09 05:06 PM
Tucson AZ
2
2cudabuck Offline
2cudabuck  Offline
Tucson AZ
I did mine on my road race car, with just a summit tubing kit. But , if someone can help him measure the actual route of the lines, and get pre-flared lines to bend into place, I would think that would be the way to go.
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: Who makes their own brake lines?? [Re: 2cudabuck] #204927
01/26/09 05:21 PM
01/26/09 05:21 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If you do it with the coated lines be sure to clean the coating off of the area that will form the flare. I've seen lines leak at the fittings because of this.
Re: Who makes their own brake lines?? [Re: HealthServices] #204928
01/26/09 11:32 PM
01/26/09 11:32 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
Don't ask me how I know.
If I can bend my own brake lines. Anyone can.
Re: Who makes their own brake lines?? [Re: DaytonaTurbo] #204929
01/26/09 11:58 PM
01/26/09 11:58 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
I do all my own lines. You can buy a 25' roll of 3/16 steel line, which is way plenty. Fittings are pretty cheap, but I re-use mine unless they are rusty and all wopperjawed.
Re: Who makes their own brake lines?? [Re: JDMopar] #204930
01/27/09 08:37 AM
01/27/09 08:37 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
There is a guy on ebay selling a preflared brakeline assortment ranging in length from 6" to 50" for about $50 delivered. With the exception of the front/rear line, I was able to fabricate all of the rest of the lines using this kit. I hate flaring, so this kit was worth it. See: chrysleroldtimeparts. Since the lengths are fixed, use a coat hanger or bailing wire of the same length and fit it to the application before bending the line.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Who makes their own brake lines?? [Re: DaytonaTurbo] #204931
01/27/09 09:17 AM
01/27/09 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Any parts store will have decent line you can bend. Make sure you get the double flair right....
Re: Who makes their own brake lines?? [Re: Mr.Yuck] #204932
01/27/09 09:44 AM
01/27/09 09:44 AM
the house on the left.
cogen80 Offline
cogen80  Offline
i agree. they are easy to make.
Re: Who makes their own brake lines?? [Re: cogen80] #204933
01/27/09 02:15 PM
01/27/09 02:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I use a 1/4" drive 5/16, 11/32 or 3/8 socket held in a vise as a bender/dowel. Works great. Just move slowly along the radius of the bend.
Re: Who makes their own brake lines?? [Re: RobX4406] #204934
01/27/09 02:21 PM
01/27/09 02:21 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
This is kinds O/T, but who makes a descent double flairing tool? I bought one from the parts store and it wasnt worth a turd.
Re: Who makes their own brake lines?? [Re: RacerGofKGB] #204935
01/27/09 02:41 PM
01/27/09 02:41 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
on thing often overlooked when flaring ends is deburring. when you cut the line with the pipe cutter it leaves a big bur along the I.D. of the tube. take a tapered carbide bit (can't remember the correct name this this tool) and just knock the bur off. ever since i have started doing this i have never had a double flare leak
Re: Who makes their own brake lines?? [Re: prochargedhemi] #204936
01/27/09 03:51 PM
01/27/09 03:51 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
i agree , good idea to debur.
Also the quality of the flair tool can make a difference in the finished flair.
I wore out my 30 year old one recently and had to buy 4 of them in order to find one that flaired properley
And it ended up being the cheapest one.
Old Fogey Racing Ltd.
Re: Who makes their own brake lines?? [Re: prochargedhemi] #204937
01/27/09 08:48 PM
01/27/09 08:48 PM
what is a reamer? Sorry too much jeopardy .
Re: Who makes their own brake lines?? [Re: RapidRobert] #204938
01/27/09 11:03 PM
01/27/09 11:03 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
One of the best tools I have ever bought is my mastercool hydraulic flaring tool. It wasn't cheap (search ebay) but man I can make a brake line in no time and they never leak. LOL, It is probably a no no or something but I use a drill bit to de burr, and I like the tubing bending pliers from Eastwood......
