727 Question #2045866
04/04/16 12:28 AM
04/04/16 12:28 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I want to do a 360 in my '82 Fury but I'm not convinced the stock 904 can handle it. Is there a beefed-up torque converter available for the 904 that will handle the additional torque and has the balance weight? If not what vehicle do I spec to find a 727 w/ lockup? This is my daily driver
Re: 727 Question [Re: jeebis44] #2045920
04/04/16 01:20 AM
04/04/16 01:20 AM
Tacoma, Washington USA
Adam71Charger Offline
Is it a stock 360 with no performance enhancements?
Re: 727 Question [Re: jeebis44] #2045925
04/04/16 01:26 AM
04/04/16 01:26 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Don't know why it wouldn't. I'm about to put just short of 500HP to my built 904. Have a converter built by a reputable company. I had PTC build mine, and you can specify having the weights welded on.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 727 Question [Re: jeebis44] #2045928
04/04/16 01:27 AM
04/04/16 01:27 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I'm looking at doing a 360 w/ magnum heads, Lunati voodoo 256/262 cam and possibly headers. 4000# car w/ 2.94 rear
Re: 727 Question [Re: jeebis44] #2045934
04/04/16 01:34 AM
04/04/16 01:34 AM
I don't know if beef up is the right term for a converter, but at the least I would call a good converter company and have them build you something that works best for your combo
Re: 727 Question [Re: jeebis44] #2045939
04/04/16 01:37 AM
04/04/16 01:37 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I know that the stock 904 converters like to break the torque converter snout off in high torque applications... wondering if there is a company that does stronger than stock TQ snouts
Re: 727 Question [Re: jeebis44] #2045957
04/04/16 02:01 AM
04/04/16 02:01 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
904 performance converters come with chromemoly hubs...and you can buy harden pump gears if that helps ya sleep at night...
Tony
70 AARCuda Vitamin C
Re: 727 Question [Re: jeebis44] #2045995
04/04/16 03:07 AM
04/04/16 03:07 AM
Are you trying to keep this conversion low cost?
Re: 727 Question [Re: jeebis44] #2046029
04/04/16 04:43 AM
04/04/16 04:43 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
"I know that the stock 904 converters like to break the torque converter snout off in high torque applications... wondering if there is a company that does stronger than stock TQ snouts"
"904 performance converters come with chromemoly hubs...and you can buy harden pump gears if that helps ya sleep at night..."
Well, there is always the option for 904's that I've been posting on here for about 10 years now - using the A500 pump gears and order your converter with that style pump drive - they have flats instead of the crack prone slots.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 727 Question [Re: jeebis44] #2046031
04/04/16 04:49 AM
04/04/16 04:49 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I am definitely trying to keep costs down
Re: 727 Question [Re: jeebis44] #2046155
04/04/16 12:11 PM
04/04/16 12:11 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
So I would just order an A500 front pump assembly and then the A500 lockup torque converter? and throw that in the 904?
Re: 727 Question [Re: jeebis44] #2046190
04/04/16 12:45 PM
04/04/16 12:45 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
No, you just put A500 pump gears into the 904 front pump, and order your 904 converter with the A500 pump drive. Been doing it for years.
Re: 727 Question [Re: jeebis44] #2046352
04/04/16 04:13 PM
04/04/16 04:13 PM
If it were me, since the engine is out and the front pump of the tranny is coming out too, I would go ahead and rebuild the trans or at least new clutches. I think my complete performance rebuild kit was around $200, maybe less. Would have been less for standard rebuild kit
