B&M 174 blower on a 408 stroker? #2042071
03/30/16 04:57 PM
03/30/16 04:57 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline OP
I'm wondering if it is worth the trouble.. I have a 408 that is fresh not assembled has steel crank and kb pistons ( not forged ). From previous experience it should come out around 9.5 comp with the heads I'm using .
This combination made about 450hp without the blower . I'm wondering if I can get past 500 with the little blower. I have it already with all the parts to install it . I'm going to put it in a 76 duster with a 904 9.5 converter 4:10's and rip around town in it and what I'm really looking for is some numbers on the mobile chassis dyno.
The cast pistons are a worry I can always add race gas for the dyno runs!
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: B&M 174 blower on a 408 stroker? [Re: SANDYinNS Canada] #2043357
04/01/16 09:36 AM
04/01/16 09:36 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Depending on the pulley size it should be a riot. Doing the math a 174 blower with a 2:1 ratio should produce around 7psi on a 408. If you add the 7psi to 450hp using Wallace racing calculators you should be well over 600hp... Probably happy numbers but it will def. be over 500hp. What pulley setup do you have?
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: B&M 174 blower on a 408 stroker? [Re: SANDYinNS Canada] #2043380
04/01/16 10:46 AM
04/01/16 10:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think you'd be well over 500 w/ a mild amount of boost. You can also toss those 4.10's and drop to 3.55's
Coming soon!!!!
