Re: Strange starter problem
[Re: 383man]
#2040630
03/28/16 08:10 PM
03/28/16 08:10 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
When it did this was it just one click when you tried to start it or did it keep clicking like a machine gun sound ? Ron Just one click which I assume rules out the battery?
[Re: dd340]
#2040771
03/28/16 10:46 PM
03/28/16 10:46 PM
RapidRobert
My very first thought was the starter but 10 seconds later I was thinking that ain't 12V at the batt kind of low for a fully charged one?? What I WOULD do is sub in a known good fully charged batt & that will quickly elim or confirm that it it the batt, then if not you can go thru the harder job of pulling the starter (harder than dropping in a batt). Holler how it turns out. PS Yes that is a STRANGE symptom!
[Re: RapidRobert]
#2040789
03/28/16 10:57 PM
03/28/16 10:57 PM
dd340
Ottawa, ontario
My very first thought was the starter but 10 seconds later I was thinking that ain't 12V at the batt kind of low for a fully charged one?? What I WOULD do is sub in a known good fully charged batt & that will quickly elim or confirm that it it the batt, then if not you can go thru the harder job of pulling the starter (harder than dropping in a batt). Holler how it turns out. PS Yes that is a STRANGE symptom! I put a battery charger on it and the voltage on the battery was around 14v and I had the same issue. I would be surprised if it was the battery.
[Re: dd340]
#2040802
03/28/16 11:08 PM
03/28/16 11:08 PM
RapidRobert
Alright we've eliminated the batt. I'd bet on the starter now
[Re: dd340]
#2040818
03/28/16 11:26 PM
03/28/16 11:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
the battery should be 12.8V or above without a charger on it.
14V is the charger, I bet it's not 14V when cranking.
What does the voltage drop to when it cranks, without the charger on it?
That will tell where your battery is.
[Re: Supercuda]
#2040834
03/28/16 11:52 PM
03/28/16 11:52 PM
RapidRobert
Supercuda is right, see what your cranking voltage is (at the batt terminals)
[Re: poorboy]
#2041001
03/29/16 09:09 AM
03/29/16 09:09 AM
dd340
Ottawa, ontario
I'd change the battery cables before I replaced the starter, just because.
Are you just holding the key to crank for those 10 seconds and then the starter takes off, or are you cycling the key until it finally takes off after about 10 seconds of continuously turning the key from off to start? If your cycling the key off and on, and the battery has at least 12.8 volts, the starter is probably junk. Gene
I am just holding the key in the start position and then after holding it for 10 secs it takes off. I'm not cycling it on and off.
[Re: 383man]
#2041003
03/29/16 09:14 AM
03/29/16 09:14 AM
dd340
Ottawa, ontario
Just one click then its most likely the solenoid contact is dirty. Seen it alot on the more modern small starters. If it was a cable or battery problem it would be low voltage which will make the solenoid clatter since when it conects the starter circuit to the battery the solenoid will drop back out because the starter draws what amps it can trying to work and the low voltage causes the solenoid to kick back out and as soon as it does the starter disengages and the voltage gets high enough to pull the solenoid back in. This happens over and over and causes the clattering like a machine gun sound. A low battery and low voltage will usually cause it to do that. Now if the battery cable was fully an open circuit it could do that.
Try this.........turn your headlites on and then crank it and see what the headlites do. If they stay bright its an open circuit which is most likely a dirty solenoid contact. If the lights go dim it low voltage and if the lites go out its a very bad connection. Ron I will give that a try. What is the fix for dirty solenoid contacts? New starter or can it be fixed easily?
[Re: Supercuda]
#2041448
03/29/16 10:02 PM
03/29/16 10:02 PM
dd340
Ottawa, ontario
I did some further testing tonight. The battery voltage is at 12.0v without the charger on. When engaging the starter it drops to about 10.5v. This would seem low to me. The really funny part is that this evening the starter cranked on the first turn of the key, no delay at all. I cranked it 5-6 times and only once was there a delay for maybe 1 sec. All the other times it cranked right away.
[Re: dd340]
#2041502
03/29/16 10:53 PM
03/29/16 10:53 PM
RapidRobert
10.5 looks good, the old spec from the 60's was 9.6 or better & you're well over that. I'd pull that starter
[Re: dd340]
#2041554
03/29/16 11:38 PM
03/29/16 11:38 PM
Supercuda
About to go away
About to go away
up yours
10.5 is ok, but your battery is a bit discharged at 12.0V, put it on a trickle charger over night, preferably a conditioning one. When there was the delay did the voltage drop as well? If not your issue is the starter, probably the contacts mentioned. Repair kit for the contacts. $13.38 http://www.rockauto.com/en/moreinfo.php?pk=4779651&cc=1087589&jsn=390
