8 3/4 rear Disc brake kits #2031399
03/15/16 12:25 AM
03/15/16 12:25 AM
Rescue CA.
joes68340s Offline OP
Rescue CA.
I'm looking for a kit that uses the factory adjustable bearings. Every kit I have looked at is for green bearings. Am I stuck using those crappy bearings.
Re: 8 3/4 rear Disc brake kits [Re: joes68340s] #2031414
03/15/16 12:52 AM
03/15/16 12:52 AM
Portland, OR
shawge Online content
shawge  Online Content
Portland, OR
Have you looked at DrDiff's kits?
http://www.doctordiff.com/brakes/rear/
Re: 8 3/4 rear Disc brake kits [Re: joes68340s] #2031424
03/15/16 01:09 AM
03/15/16 01:09 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Nope. As far as I know, Dr Diff is the only ones you can use tapered bearings with.
Re: 8 3/4 rear Disc brake kits [Re: MuuMuu101] #2031437
03/15/16 01:32 AM
03/15/16 01:32 AM
Rescue CA.
Rescue CA.
Ok Thanks I missed that one.
Re: 8 3/4 rear Disc brake kits [Re: joes68340s] #2031873
03/15/16 07:53 PM
03/15/16 07:53 PM
IN
ahy Offline
ahy  Offline
IN
Here is a pic of the Dr Diff setup. I had roasted my drums at a track day and next time out had this disk setup. Worked great and much better balanced braking.
To dial in the end play you need to slightly lengthen one axle or add adjusters on both sides. I lengthened the axle by welding a small thick hardened washer on the end.
Re: 8 3/4 rear Disc brake kits [Re: ahy] #2031978
03/15/16 10:24 PM
03/15/16 10:24 PM
Rescue CA.
Rescue CA.
Thanks good to know.
Re: 8 3/4 rear Disc brake kits [Re: joes68340s] #2041042
03/29/16 09:26 AM
03/29/16 09:26 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
I did manage to setup a Wilwood kit with OEM bearings a few years back, but I had to have someone fabricate a metal piece on a lathe to put inside the diff, between the two axles, so they could butt against each other (tapered bearings equalize the load on both wheel bearings, so you need to be able to tighten the axles together to almost zero lash).
The Wilwood aluminum flanges added a lot of distance compared to the drum backing plates, so much the adjuster could not be used alone to correct this. If you're having new axles custom made, you can add the difference to their length.
If I had to do it again though, I'd go with a kit from DrDiff, as :
- The Wilwood inner drums for a parking brake are a joke, they do not brake worth a damn, and the aluminum flange can bend *very* easily.
- Everything I've ever bought from DrDiff was top notch, *really* bolt-on stuff.
Re: 8 3/4 rear Disc brake kits [Re: fbernard] #2041099
03/29/16 11:11 AM
03/29/16 11:11 AM
Trumussia
jcc Offline
jcc  Offline
Trumussia
Not clear to me in your comment, are the Wilwood's an effective "parking brake"?
If you can't dazzle them with diamonds, don't waste your time, because nothing will
Re: 8 3/4 rear Disc brake kits [Re: fbernard] #2041127
03/29/16 11:47 AM
03/29/16 11:47 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Not surprising, internal drum parking brakes are notoriously weak. Even my factory Jeep Wrangler setup never worked well from day one. The small diameter requires a pretty high clamping load to get to the holding power of a "normal" 10-11" diameter drum brake.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 8 3/4 rear Disc brake kits [Re: jcc] #2041944
03/30/16 01:27 PM
03/30/16 01:27 PM
fbernard Offline
fbernard  Offline
I wrote "they do not brake worth a damn".
As in "Start the engine, drive off, and if you notice a slight drag after a couple minutes of driving around, you probably forgot to release the parking brake".
Wilwood's calipers, rotors and hats are pretty good in my opinion, but the hardware is not.
