This Cam good for this engine ?
#2041724
03/30/16 05:43 AM
03/30/16 05:43 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Old war horse 440 + 30 engine is out of my sons play car for a quick rings, bearings, cam swap and converter. Engine is a LY rod 440+30 TRW's about 11:1 with max port indy sr's that flow 370 with indy 4150 intake and 1000cfm quick fuel carb. Trans is freshly tricked 727 with new 5000 converter, old one was 3500. I have had the engine for 20 years and cant remember the cam that's in there only that it was 600 lift ?? solid. Years ago this engine was in my old 63 Ply on the bottle running 9.70's but now is semi retired. It ran 11.2 @ 123 first time out for the boy but came out of the hole like a slug, 1.7 60'. I have this cam on the shelf with it's lifters. Would like your thoughts on it, keeping in mind that the young gun don't have mountains of cash. Thanks
1963 Plymouth Max Wedge 1971 Barracuda
Re: This Cam good for this engine ?
[Re: ahy]
#2041756
03/30/16 10:17 AM
03/30/16 10:17 AM
DaytonaTurbo
Manitoba, Canada
What's wrong with the .600 solid that's in it now? Not sure how long the heavy pistons + LY rods will last running over 6000 RPM though. According to the OP, 20 years and counting....
[Re: ozymaxwedge]
#2041766
03/30/16 10:43 AM
03/30/16 10:43 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I would like to take more advantage of the heads and go with a 1.6 rocker. But like it was mentioned, the rods and pistons are going to be the weak link.
[image][/image]
[Re: ozymaxwedge]
#2041806
03/30/16 11:32 AM
03/30/16 11:32 AM
ozymaxwedge
Australia
^^ Yeah, we only have 1.5 Crane Golds on it.
[Re: ahy]
#2041810
03/30/16 11:37 AM
03/30/16 11:37 AM
ozymaxwedge
Australia
Good heads, lots of duration, lots of stall and decent compression. I think it will work as a drag cam. Goes without saying, the engine will need to spin pretty fast. Not sure how long the heavy pistons + LY rods will last running over 6000 RPM though. The poor thing was @ 7200 through the stripe when I had it Hate to say this but 7 pistons are TRW and one is a Manley that was almost the same just a slight difference on the top that I rectified with a die grinder. What can I say I had 3 days to get it back on the track and no money
[Re: ozymaxwedge]
#2042167
03/30/16 07:08 PM
03/30/16 07:08 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Al , if the old cam had more lift I imagine it may be bigger duration . However the bigger vert will help out of the hole - if it hooks up . 123mph should be well in the 10's.Why not reuse that cam ? Especially as the heads will flow with the lift . That Reed cam looks about 1 size bigger than my Camtech , and less lift hasn't hurt it . It should be easy on the valve train though .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2042194
03/30/16 07:53 PM
03/30/16 07:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would use the cam thats in it.. but I would advance it for more torque and so it runs out of rpm sooner.. I wouldnt trust 20 year old LY rods that have been spinning hard.. or replace the rods with some H-beams
[Re: ozymaxwedge]
#2042225
03/30/16 08:38 PM
03/30/16 08:38 PM
ozymaxwedge
Australia
Cheers guys, the old cam has seen better days, looks like it has started to lose the tops of the lobes, its junk. Hey P Body, the LY rods are not 20 years old, more like 46 years old THANKS
[Re: ozymaxwedge]
#2042228
03/30/16 08:44 PM
03/30/16 08:44 PM
MR_P_BODY
Cheers guys, the old cam has seen better days, looks like it has started to lose the tops of the lobes, its junk. Hey P Body, the LY rods are not 20 years old, more like 46 years old THANKS Well you got the idea about the rods... they're worn out and waiting to break.... too bad about the cam... I guess that settled the question
[Re: ozymaxwedge]
#2042251
03/30/16 09:15 PM
03/30/16 09:15 PM
tex013
Sydney,Australia
Like MrP - too bad about the cam well run what ya got . LY rods - awesome got em in my motor . But I got SRP pistons , light Look forward to hearing some new et's Tex
