Re: Disc brake proportioning valve 1973 plymouth satellite
[Re: VegasCharger]
#2041301
03/29/16 04:43 PM
03/29/16 04:43 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Yup 73-74 P-valve good to go on 71-72 w/ disc brakes. . The one in your pic I think is from an E-body though.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2041323
03/29/16 05:32 PM
03/29/16 05:32 PM
Posts: 369 Akron, Ohio
VegasCharger
Akron, Ohio
Yup 73-74 P-valve good to go on 71-72 w/ disc brakes. . The one in your pic I think is from an E-body though. Thanks for your info. But I'm most certain that this pv is original to the car (1973 B Body w/disc brakes).
[Re: VegasCharger]
#2041335
03/29/16 05:55 PM
03/29/16 05:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Are the rear drum sizes the same? that'll vary the application as well
[Re: Supercuda]
#2041359
03/29/16 06:38 PM
03/29/16 06:38 PM
VegasCharger
Akron, Ohio
Are the rear drum sizes the same? that'll vary the application as well So 10" vs 11" drums would require a different pv? The one pictured above is from a 10" application.
[Re: VegasCharger]
#2041370
03/29/16 06:59 PM
03/29/16 06:59 PM
DARTH V8Я
Its a TRAP!
IMHO 10" or 11" drums you'll be fine. The swap to larger rear drums have been done many times without any problems.
[Re: VegasCharger]
#2041388
03/29/16 07:33 PM
03/29/16 07:33 PM
Supercuda
About to go away
About to go away
up yours
IYO maybe, the factory disagreed.
The job of the combination valve is to marry two substantially different braking systems, disc vs drums. Discs are fairly linear in application, self energizing drums are not. For example, my 87 M body had two different PV's available, the only difference in the braking system was 10" vs 11" drums. I don't plan to redesign the braking system so I tend to follow what he factory did when updating my brakes.
[Re: Supercuda]
#2041407
03/29/16 07:47 PM
03/29/16 07:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I would think it should be fine. Thats actually a combination valve that has the Proportioning valve and the Metering valve in it with the balance valve for the brake lite. I would try it and see how it works. Do some hard and light braking and see how the rear bakes act. The prop valve will limit pressure to the rear brakes on hard braking so the rear dont lock up and the Metering valve will hold the front brakes off on light braking until the rear reach a certain pressure or overcome the spring tension. Ron
[Re: VegasCharger]
#2041425
03/29/16 08:25 PM
03/29/16 08:25 PM
Supercuda
About to go away
About to go away
up yours
383 you are right, but the spring tension is different between 10" and 11" drums, one of the difference, not to mention the kneepoint setting difference. A decent write up, not too technical, but hits the high points. http://stoptech.com/technical-support/technical-white-papers/proportioning-valves
[Re: VegasCharger]
#2041488
03/29/16 09:37 PM
03/29/16 09:37 PM
Supercuda
About to go away
About to go away
up yours
I dunno, maybe I am just a turd polisher
[Re: Supercuda]
#2041780
03/30/16 10:08 AM
03/30/16 10:08 AM
Posts: 20,779 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
The job of the combination valve is to marry two substantially different braking systems, disc vs drums. Discs are fairly linear in application, self energizing drums are not. For example, my 87 M body had two different PV's available, the only difference in the braking system was 10" vs 11" drums. I don't plan to redesign the braking system so I tend to follow what he factory did when updating my brakes. this is true. but, when you change or stagger tire sizes [think big & littles], it may be best to replace the factory valve with an adjustable aftermarket item. this may also apply to the pad/shoe material in use compared to the factory material, although to a differing degree i suppose. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Supercuda]
#2041856
03/30/16 11:42 AM
03/30/16 11:42 AM
DARTH V8Я
Its a TRAP!
Done it before with zero issues, I'll do it again. I'd only go A/M on the valve if I'm going the rear disc route.
[Re: VegasCharger]
#2041994
03/30/16 02:12 PM
03/30/16 02:12 PM
Posts: 21,147 Niles , Ohio
therocks
Niles , Ohio
My 65 runs a PP from a 5th ave.Been on since 99 and no problems.read an article years ago by a Mopar master cant remember who now.He said pretty much they will interchange as it dosent matter a lot.Many factory changes were mandated by feds etc.Rocky
Chrysler Firepower
[Re: VegasCharger]
#2042161
03/30/16 05:56 PM
03/30/16 05:56 PM
Supercuda
About to go away
About to go away
up yours
An adjustable proportioning valve handles exactly ONE aspect of what a factory combination valve handles, proportioning and that is it. Thge factory combination valve does a whole lot more.
You do not want a combination valve with rear discs nor should you need one with a properly designed all disc system since the front and rear behave the same and you can adjust bias with bore sizing.
If you are going to the effort of junkyarding a combination valve why not get the right one and not one "close enough"?
[Re: Supercuda]
#2042350
03/30/16 10:40 PM
03/30/16 10:40 PM
383man
Balt. Md
I dunno, maybe I am just a turd polisher No your just a perfectionist which is good and I try to be but sometimes it does make us think to much. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Ron
