Re: indy 440-1 ex port ?
[Re: mopar dave]
#2041166
03/29/16 02:00 PM
03/29/16 02:00 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
3/4" I believe. Same as the SR.
[Re: BradH]
#2041244
03/29/16 04:15 PM
03/29/16 04:15 PM
an8sec70cuda
mopar dave...if you're thinking of header fitment, typically, a low deck w/ raised port heads will use an RB header. An RB will need specific raised port headers, or in some cases, a standard fenderwell will still work w/ the raised ports.
[Re: mopar dave]
#2041258
03/29/16 04:36 PM
03/29/16 04:36 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
The 440-1 exhaust ports are way bigger stock, width and hiegth than any other head, except B1, B1MC, made out there that I'm aware of I had to have a special set of headers made to clear those ports TTI makes and sells them, I'm a dealer for them also
[Re: mopar dave]
#2041279
03/29/16 05:19 PM
03/29/16 05:19 PM
an8sec70cuda
The ports are larger than std. ports, but I've seen people using standard headers w/ Indy heads. Not the way I'd do it, but I guess it works OK. Obviously there's some restriction there. You can take a normal set of headers and have the larger flanges welded on...may save some money over a set specifically for those heads. Especially if you already own a set of std. port headers. Personally, I've always used the TTI headers made for the larger ports.
