Re: Trick Flow heads
[Re: fast68plymouth]
#2050477
04/09/16 04:39 PM
04/09/16 04:39 PM
fast68plymouth
So. Burlington, Vt.
Is that 1050/4150 one that has the baseplate that will fit either 4150 or 4500 manifolds? If so, did you try it on the other intake?
#2050522
04/09/16 06:05 PM
04/09/16 06:05 PM
Posts: 31,082 Oregon
AndyF
Is that 1050/4150 one that has the baseplate that will fit either 4150 or 4500 manifolds? If so, did you try it on the other intake? yes, the QF carb will bolt to either a 4150 or 4500 intake but it doesn't exactly work on a 4500 intake without some other fixes so I didn't run it that way. That would be a good thing to test at some point.
[Re: AndyF]
#2050559
04/09/16 06:58 PM
04/09/16 06:58 PM
dartman366
Mt. Vernon, Ohio
No, I didn't think about that until too late. I didn't take the adapter with me. My guess is that the Dominator on an adapter would've pushed the TF intake up another 10 hp or so. Look's like I have just settled on which intake that I am going to use on my 512, thanks for the time and effort Andy, I have been waiting on this info to help me make up my mind, wish TF made the low deck manifold with the dominator flange, but it looks like I will use my existing 2" spacer and do a little blending. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
#2050602
04/09/16 08:25 PM
04/09/16 08:25 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Did the gap from max torq & max Hp open up at all? Last I seen back in this thread was like only 600 rpm apart iirc.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: dartman366]
#2050625
04/09/16 09:41 PM
04/09/16 09:41 PM
Thumperdart
State of confusion
No, I didn't think about that until too late. I didn't take the adapter with me. My guess is that the Dominator on an adapter would've pushed the TF intake up another 10 hp or so. Look's like I have just settled on which intake that I am going to use on my 512, thanks for the time and effort Andy, I have been waiting on this info to help me make up my mind, wish TF made the low deck manifold with the dominator flange, but it looks like I will use my existing 2" spacer and do a little blending. If you want the most from the adapter, I`d deep blend it into and shape the upper most part of the intake cos the results are awesome..........
[Re: Thumperdart]
#2050677
04/09/16 11:03 PM
04/09/16 11:03 PM
dartman366
Mt. Vernon, Ohio
No, I didn't think about that until too late. I didn't take the adapter with me. My guess is that the Dominator on an adapter would've pushed the TF intake up another 10 hp or so. Look's like I have just settled on which intake that I am going to use on my 512, thanks for the time and effort Andy, I have been waiting on this info to help me make up my mind, wish TF made the low deck manifold with the dominator flange, but it looks like I will use my existing 2" spacer and do a little blending. If you want the most from the adapter, I`d deep blend it into and shape the upper most part of the intake cos the results are awesome.......... Thats exactly my plan. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: AndyF]
#2050850
04/10/16 04:42 AM
04/10/16 04:42 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
That is my "topless valve cover"! It works pretty well. This engine has a well sorted out valve train so there isn't a lot of oil spraying around. Just 8 streaks of oil on the valve cover. Each rocker arm sprays a small streak of oil on the lid from the roller wheel.
I would like to see a video of that in action.
1974 Roadrunner
1967 Charger
#2051774
04/11/16 12:50 PM
04/11/16 12:50 PM
AndyF
Is that 1050/4150 one that has the baseplate that will fit either 4150 or 4500 manifolds? If so, did you try it on the other intake? I needed one of my AR372 plates to run the QF 1050 on the Wilson intake but I forgot to take one with me. If you bolt the 4150 carb directly to the M1 intake the linkage hits the manifold. There is also sometimes a leak since the 4150 baseplate doesn't always cover the opening in the 4500 intake.
[Re: GY3]
#2052276
04/11/16 10:51 PM
04/11/16 10:51 PM
AndyF
Does Wilson do port work on other brands of manifolds as well? I'm pretty sure that if you have the money they'll port whatever your drag in the door. Check out the cool stuff on their website: http://www.wilsonmanifolds.com/
[Re: Street Monkies]
#2052283
04/11/16 10:53 PM
04/11/16 10:53 PM
AndyF
Andy let me know if you plan on selling the trick flow intake. I had cash the last time I messaged you about parts. Thanks I don't think I'll sell this Trick Flow intake anytime soon. I might be willing to make you a good deal on a very slightly used Victor 383 though.
[Re: AndyF]
#2052837
04/12/16 03:27 PM
04/12/16 03:27 PM
Posts: 126 Oregon
Jamie McGrath
Here is an outside shot of a stock intake and then the second picture shows the outside of the ported intake. It appears that Wilson welded up the outside so they could open up the ports. The stock intake has almost an inch between the center runners while the Wilson intake has a V between the runners. Andy, I was waiting for someone else too ask and seeing as no one has, I will. What was the stock M1 intake volume compared too the reworked Wilson M1 intake volume? Just wondering as it really picked up after reworking it looks huge inside but it must also be moving plenty of air pretty fast. Did they give you some type of flow sheet?
