Re: Best lube for heater blower motor
[Re: bonefish]
#2039622
03/27/16 11:48 AM
03/27/16 11:48 AM
RapidRobert
I'd use a small dollop of grease out of your grease gun
[Re: Stanton]
#2040356
03/28/16 12:38 PM
03/28/16 12:38 PM
RapidRobert
I never grease a bronze bushng, they're meant to hold oil. Grease is for bearings. Noted
[Re: jbc426]
#2041763
03/30/16 10:37 AM
03/30/16 10:37 AM
Posts: 27,728 places
79powerwagon
places
If it didn't work, of course. But since it works fine other than needing lube, I'll simply fix it.
[Re: 79powerwagon]
#2041771
03/30/16 10:54 AM
03/30/16 10:54 AM
Posts: 4,272 Morrow, OH
markz528
Morrow, OH
If it didn't work, of course. But since it works fine other than needing lube, I'll simply fix it. Rarely will re-lubing work long-term once the bushings are damaged.
[Re: 79powerwagon]
#2042287
03/30/16 10:43 PM
03/30/16 10:43 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
If it didn't work, of course. But since it works fine other than needing lube, I'll simply fix it. I hope it works out for you. It would be nice if a little lube did the trick. If I were dead set on lubing those small bushings, I'd use synthetic disc brake grease. Fill the bushings with grease, put them inside a small assembly of galvanized pipe parts that make up an air tight container and pressurize the galvanized pipe with compressed air to drive the lube into the bronze. I used to pre-oil my pilot bushings by placing the bushing on my palm, filling it up with oil and capping the top with my thumb. I would try to compress the oil by pushing down with my thumb until I saw it weeping through the bushing.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 79powerwagon]
#2042306
03/30/16 11:14 PM
03/30/16 11:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
hmm, an oilite bushing needs lube OILite bushing, wonder what lube you should use in an OILlite bushing. Grease? Oh sure that's what belongs in an OILite bush. 30w is typically what is used. https://en.wikipedia.org/wiki/Oilitehttp://www.webcitation.org/5m66FprSI says " Can be re-oiled when dry (submerse in SAE 30 motor oil for 72 hours at room temperature to replenish"
