440 rod knock? #2039238
03/26/16 05:45 PM
03/26/16 05:45 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
Rebuilt in 2012, approx 500mi on rebuild. Mostly stock rebuild with 440source heads, 60303 Voodoo cam, stock rockers-intake-exhaust manifolds. Started up this morning and heard what sounds like a rod knock at idle that goes away with rpm. Link to youtube vid below, initially at idle, then rpm, then back to idle.
Haven't done any testing as yet, thought I'd wait for the experts to weigh in.
PS...good oil pressure, about 50psi at idle.
440 knock?
Re: 440 rod knock? [Re: 70runner] #2039242
03/26/16 05:54 PM
03/26/16 05:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Video is private which means we can't see it. Are you sure it isn't converter bolts loose or hitting the shield?
Re: 440 rod knock? [Re: 70runner] #2039249
03/26/16 06:05 PM
03/26/16 06:05 PM
70runner Offline OP
70runner  Offline OP
Hopefully video is viewable now. Will check converter bolts, but doesn't sound like that to me.
Re: 440 rod knock? [Re: 70runner] #2039264
03/26/16 06:27 PM
03/26/16 06:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what pistons?
Re: 440 rod knock? [Re: 70runner] #2039317
03/26/16 08:13 PM
03/26/16 08:13 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
It doesn't sound like a rod knock to me.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 440 rod knock? [Re: 70runner] #2039319
03/26/16 08:17 PM
03/26/16 08:17 PM
70runner Offline OP
70runner  Offline OP
.030 over SRP 213455 (10.5:1CR) flat top with SCAT 4340 H beam rods
Re: 440 rod knock? [Re: 70runner] #2039320
03/26/16 08:17 PM
03/26/16 08:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would suggest you hit the parts store for a cheap mechanics stethoscope and see what you can hear. A rod knock should have gotten louder and more rapid with the RPM change.
Re: 440 rod knock? [Re: 70runner] #2039335
03/26/16 09:06 PM
03/26/16 09:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd check the converter bolts. If it was knocking that bad internally it would have lost some oil pressure. Cut the filter open and have look before you run it again.
Doug
Re: 440 rod knock? [Re: 70runner] #2039336
03/26/16 09:09 PM
03/26/16 09:09 PM
70runner Offline OP
70runner  Offline OP
IIRC, a rod knock should "peak" with no load, just after bumping the rpm. Gonna put it up on the lift, check the converter bolts and underneath. Hoping its just a rattle.
Re: 440 rod knock? [Re: 70runner] #2039343
03/26/16 09:19 PM
03/26/16 09:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
probably a straight pin piston put in around .006". they'll talk to you when cold. if things quiet down when warmed up i wouldn't worry about it.
Re: 440 rod knock? [Re: 19swinger70] #2039385
03/26/16 10:50 PM
03/26/16 10:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Too sporadic, Could be rockers hitting the valve covers, Flex plate / converter bolts or a multitude of other things. Silly question, is the timing to far advanced ??? shruggy
twocents
Re: 440 rod knock? [Re: TJP] #2039423
03/26/16 11:43 PM
03/26/16 11:43 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sounds like a lobe or two leavin town.
Re: 440 rod knock? [Re: 70runner] #2039451
03/27/16 12:24 AM
03/27/16 12:24 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
It's not a rod knock...You're on the right track check the flexplate,convertor,etc...
Re: 440 rod knock? [Re: 70runner] #2039493
03/27/16 01:42 AM
03/27/16 01:42 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Agree it doesn't sound like a rod knock. As said, check the external items like the flexplate and converter as well as the damper and pulleys. Once you eliminate the external items, you may have to go inside and look for something like a broken crank.
Re: 440 rod knock? [Re: 70runner] #2039841
03/27/16 05:07 PM
03/27/16 05:07 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Too irregular to be a rod knock. Could be converter bolts I suppose. Actually sounds more like an engine external issue like exhaust pipe slapping against chassis.
Just saying from irregularity and that only is apparent at low rpm when engine bouncing about on its rubber mounts.
Go under car while engine is running. Place a stethoscope on pan and listen for something rattling about in it.
Oil pressure all ok? How does oil on dipstick appear,,,no shiny specks?
Did I miss if automatic or stick. If stick, push in clutch,,,,any change.
I like early statement on pulleys or belts or dampener.
Re: 440 rod knock? [Re: 70runner] #2039859
03/27/16 05:25 PM
03/27/16 05:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Could pull lug wire off and on one by one while running. See if you can isolate it to one cylinder.
Here a classic rod knock with good oil pressure in my 340
Re: 440 rod knock? [Re: 70runner] #2040125
03/27/16 11:57 PM
03/27/16 11:57 PM
70runner Offline OP
70runner  Offline OP
Good news. Loose flexplate bolts, all 4. Thx to everyone who responded. Had to move the RR yesterday after taking the video in the orig post. The "clanking" was 10 times worse than on the video.
Drained the oil (due anyway) and it was clear. Cut the oil filter in half, nothing. Tightened the flexplate bolts, new oil/filter, started right up. Only thing I could hear was the lope of the Lunati 60303 smile smile smile
Re: 440 rod knock? [Re: 70runner] #2040174
03/28/16 12:43 AM
03/28/16 12:43 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 440 rod knock? [Re: 70runner] #2040300
03/28/16 09:51 AM
03/28/16 09:51 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Did you use loctite on the converter bolts? I would. Spend some time and snug all your other bolts and nuts up when its cold. You may have to snug some more than once between heat cycles for the first few thousand miles.
Re: 440 rod knock? [Re: dvw] #2040322
03/28/16 10:44 AM
03/28/16 10:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Doug
Check the convert bolts, Do you have a magnetic drain plug? If so plug it and look at it.. if it looks like "beaker" from the Muppets you have a problem. AMHIK. You can also pull the dip stick and hold it up to a bright light, if it looks like a glitter stick you may have an issue. I when I spun an bearing in the 1st 440 in this car it still had good oil pressure.
Coming soon!!!!
