crank, waterpump, alternator pulley ??
#2039053
03/26/16 10:45 AM
03/26/16 10:45 AM
Posts: 19,696 north of coder
moparx
does it matter what size pulleys you use to spin these items IF you maintain the desirable ratios needed to operate at the required output ? in other words, if a stock set of pulleys consisted of a 6 1/2" crank, 7" water pump, and 2 1/2" alternator pulley, could you substitute a set that was a smaller diameter, but contained the correct ratio that would run the items as designed ? my gut says yes, but what say you ? [ i think of things too much.....]
Re: crank, waterpump, alternator pulley ??
[Re: moparx]
#2039069
03/26/16 11:37 AM
03/26/16 11:37 AM
RapidRobert
with the Mopar alt low RPM charging issues spinning it fast is always a good thing and there are 2 sizes of alt pulleys and the largest crank pulley is I believe a 7&1/4 and I have ran into a pump pulley that was big enough that the 7&1/4 crank pulley would not work. it is possible to spin the pump too fast & get into cavitation at higher RPM's but I wouldn't sweat that & the cav plate (easy to add) pretty much elims that & gives you a far more efficient pump. Short version: the big prob with pulleys is matching a set with the right depths/offset so the belts line up. I'd use the smaller alt pulley and the 7&1/4 crank pulley and a pump pulley roughly close to its dia (not a dealbreaker) whatever you have of the right depths for belt alignment and using as short of belts as possible is always a good idea
[Re: moparx]
#2039071
03/26/16 11:40 AM
03/26/16 11:40 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes, the ratios are what's important, not the diameters.
[Re: moparx]
#2039561
03/27/16 09:37 AM
03/27/16 09:37 AM
Supercuda
About to go away
About to go away
up yours
Don't forget that for a given RPM a larger pulley has a higher speed around the circumference, which could cause the belt to jump. More info than you probably want in the link https://books.google.com/books?id=1LS2Bg...ing&f=false
