What is the best way to kill 4-5 tenths for index racing? #2037857
03/24/16 04:21 PM
03/24/16 04:21 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Pull timing?
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037862
03/24/16 04:25 PM
03/24/16 04:25 PM
an8sec70cuda Offline
With the Camaro, we used to kill a few tenths by changing the launch rpm and adding tire pressure so the slicks slipped a little. It worked great for the 6.0 index class (1/8 mile) we used to run. The car would go 5.70s in good air.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What is the best way to kill 4-5 tenths for index racing? [Re: an8sec70cuda] #2037876
03/24/16 04:44 PM
03/24/16 04:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We use a little trick and move the linkage up one hole on the carburetor. Went from 9.83 to 10.11 and didn't skip a beat.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: Dragula] #2037893
03/24/16 05:02 PM
03/24/16 05:02 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
How much rpm did You lose on the top end to lose 0.4 sec?
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037899
03/24/16 05:11 PM
03/24/16 05:11 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
A lot of guys I know use a stop under the gas pedal. Others use a plate under the carb, like a T/S but not electrically controlled. Doing these things can affect reaction time which might be a good thing with no box???
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037901
03/24/16 05:15 PM
03/24/16 05:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Weight. Timing. Shift points. I wouldn't get excessive with retarding the timing. 3 speed footbrake? Try leaving in second gear and see what it does. Maybe a mechanical stop like a Moroso 65042 or 65040 if you can find one. You may be surprised how much you have to do to kill that much. Try unhooking the secondaries once to see what that does.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037905
03/24/16 05:21 PM
03/24/16 05:21 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I like the second gear idea!
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037938
03/24/16 06:07 PM
03/24/16 06:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a mech throttle stop plus I lower the launch
rpm and the shift rpm to drop 1 full second.. the
mech throttle stop is set at about 1/3 throttle then
the lower rpms.. slows me from 8.96 to 10.00.... in your
case I would believe the lower launch rpm and shift rpm
would be good enough
wave
Re: What is the best way to kill 4-5 tenths for index racing? [Re: MR_P_BODY] #2037940
03/24/16 06:13 PM
03/24/16 06:13 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Some great ideas! Thanks!
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037950
03/24/16 06:31 PM
03/24/16 06:31 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Philly cheese steaks
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037975
03/24/16 07:13 PM
03/24/16 07:13 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
This is what I would use EZ PLATE
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2037980
03/24/16 07:24 PM
03/24/16 07:24 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
What type of index racing? What are the rules?
Throttle stops on a timer are the best bet if allowed
MSD Grid with programmable timing retards if allowed
If no electronic aids allowed, retard the cam and use weight
4-5 tenth's is a lot to kill and be consistent
95% of what I race is on an index
Re: What is the best way to kill 4-5 tenths for index racing? [Re: nss guy] #2037986
03/24/16 07:37 PM
03/24/16 07:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Actually slowing 4 or 5 tenths with a typical .90 type timed stop where you leave at WOT, is a lot harder to do and be consistent than it is to kill a second and a half with that set up. Has to do with stop ratios and keeping it predictable. Basically you would just be blipping the throttle. Much harder to do and be consistent than if it's on the stop for maybe 2 seconds.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038000
03/24/16 08:00 PM
03/24/16 08:00 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I went to T&T last year to see if I could slow my D50 down for the 7.0 index. I was running in the low 6.30's that night. I usually shift at 6800. I tried shifting at 5600 and it would only slow down to a 6.50. I need full throttle to leave on a Pro Tree (4 tenths).
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038003
03/24/16 08:07 PM
03/24/16 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can you can, slide the throttle cable housing
forward to give you less throttle... it takes a lt
more than you think
wave
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038006
03/24/16 08:28 PM
03/24/16 08:28 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
1/2 second is a lot of time to kill with shift points, weight,or timing. the only way that I know of to kill that much time is a throttle stop. The best way to go is a plate style like: Dedenbear or #1 stop. I use a #1 stop. If I am racing in a no electronic class I take the air cylinder off and replace it with a spring. All of the other good index racers that I know of, do it the same way. If you will only ever race non electronic, you can use an ET Genie or an Easy Plate.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: MR_P_BODY] #2038011
03/24/16 08:33 PM
03/24/16 08:33 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I have been using the Moroso mechanical stop p/n 65042 ( modified with a longer threaded rod) for over 8 years now and have been very successful with it. I am slowing about 8-9 tenths on average. I use it to slow down to 11.50 for Street Eliminator and for 11.50 index racing. Electronic and air operated stops aren`t allowed in the classes I run. I considered a plate system, did some research and talked to racers using them and came to the conclusion that my system is best for my combo. I have seen some of my fellow competitors using weight and shift points to slow but again i feel my setup works better. A word of advice: if you use the Moroso setup be sure and use a throttle linkage bracket like one from Jegs etc. so a second bolt can be used to attach the stop as it will tend to move if used only using the carb bolt. As a matter of fact I am going this Saturday to a Test and Tune to get the stop dialed in for my new motor combination.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038023
03/24/16 08:58 PM
03/24/16 08:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The old Moroso 65040 (discontinued) worked well. Maybe find one for sale somewhere or make a similar piece out of a throttle cable bracket mount
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038027
03/24/16 09:03 PM
03/24/16 09:03 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Cut your carb in half.
Have a great day
Iowan
"obsolete is neat"
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038030
03/24/16 09:08 PM
03/24/16 09:08 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Drive the stripe, it's easy. Lol
Seriously if you are index racing detune the motor so it can't go more than. 25 under. Lower compression, thicker gasket, retard cam cl, smaller carb.
