Re: What is the best way to kill 4-5 tenths for index racing?
[Re: nss guy]
#2038060
03/24/16 09:33 PM
03/24/16 09:33 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Would you still be able to cut a decent light on a pro tree (4 tenths tree)footbraking if you something like the throttle stop above.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: GY3]
#2038086
03/24/16 10:03 PM
03/24/16 10:03 PM
Posts: 17 Dover,, Pa
hemiaddict
Dover,, Pa
Keep it simple. Try unhooking the linkage to the rear of the carb. Run it as a two barrel. It will put you close. Then adjust weight, take it out or put some in as needed. It wooked very good on a 3000 pound car that ran 10.40s. first run went 10.88. A trick Steve Petty showed me 10 years ago. Jr
Jr Baum SS/AH 1979
[Re: B1HEAD_USER]
#2038117
03/24/16 10:49 PM
03/24/16 10:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
This is the best way, the champ in10.0 has had it in there cars past few years at our track.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: MR_P_BODY]
#2038172
03/25/16 12:09 AM
03/25/16 12:09 AM
Posts: 4,691 Wichita
GY3
Wichita
If you can you can, slide the throttle cable housing forward to give you less throttle... it takes a lt more than you think I'm cheap and was considering this. Maybe mark the cable in increments once I can tell how much a set amount kills.
[Re: GY3]
#2038181
03/25/16 12:29 AM
03/25/16 12:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you can you can, slide the throttle cable housing forward to give you less throttle... it takes a lt more than you think I'm cheap and was considering this. Maybe mark the cable in increments once I can tell how much a set amount kills. I'm cheap also... I made my mech throttle stop.. very simple and it works.. I'll see if the pic will post... I made this for my 1050 dom.. but you can see the idea EDIT The front round part slides into a hole the then rolls down over the rear carb stud... I did this so I could change over quickly so I could race 2 classes.. took all of about 2 minutes to change that and reset the shift light and 2 step I ran 6 or 7 10.002-10.007 in a row doing it this way.. I was super happy with it
[Re: GY3]
#2038188
03/25/16 12:47 AM
03/25/16 12:47 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Put a 'Glide in it . . . . . . Too obvious?
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: GY3]
#2038241
03/25/16 02:18 AM
03/25/16 02:18 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would spend about $1000 on things that you thing should make it go faster lol
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#2038289
03/25/16 05:41 AM
03/25/16 05:41 AM
Evil Spirit
Newport, Mi
Put a 'Glide in it . . . . . . Too obvious? Yeah that would be the cheap way to go Well, Mike, GY3 didn't mention CHEAP in his original post, so I just tossed an option on the table that nobody else had mentioned. Many, if not most cars that are set up to run 1/4 mile slow down both 60' and ET when a 'Glide is installed. In their defense, they are usually more consistent, less dependent on track prep, a little easier on drive line, and need less of a burnout, which saves on tires. So while not a cheap option, it's a valid one
[Re: GY3]
#2038327
03/25/16 10:25 AM
03/25/16 10:25 AM
Posts: 5,160 Texas
dannysbee
Texas
I would use a combination of weight and plate.
Getting old just means you were smarter than some and luckier than others.
[Re: GY3]
#2038364
03/25/16 11:22 AM
03/25/16 11:22 AM
Posts: 2,658 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think the Grid is the easiest. And it lets you leave WFO to try to cut the .400 light
2011 Drag Pak Challenger
[Re: GY3]
#2038566
03/25/16 04:06 PM
03/25/16 04:06 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
When I first bought the Arrow it would run 9.60s all out. Believe it or not with only 4 tenths in the timer and an air operated T/S the car was killer consistant.
5.53 @ 125 1/8th on the launch control..more left in her!
