? On Battery Terminals
#2035886
03/21/16 06:16 PM
03/21/16 06:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do those felt pad things work on the battery post to keep the corrosion down/away.. I've never tried them so I'm asking.. I have corrosion on the positive post... or is there something that works Thanks
Re: ? On Battery Terminals
[Re: MR_P_BODY]
#2036136
03/22/16 12:08 AM
03/22/16 12:08 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
A combo of the felt pads and some kind of protective spray is the best. Quick Cable makes good products for this.
My solution is to never run a standard wet battery. I switch everything I own over to AGM batteries and the cables all look brand new still. The wifes new car is getting one soon before any kind of corrosion can start. Plus dodge put the battery in a stupid place so I would never see the corrosion until it was too late.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#2036173
03/22/16 01:02 AM
03/22/16 01:02 AM
MR_P_BODY
I have to go to the parts store tomorrow so I'm gonna get those felts and see if they have that fluid film.. plus a few more big wire terminals to finish up the inverter install
[Re: BuckeyeBrawler]
#2036664
03/22/16 07:02 PM
03/22/16 07:02 PM
MR_P_BODY
I'm gonna try the felts and if I can find it, the fluid film or just the felts.. I'll grease the bottom side of them to try and block the gasses EDIT A buddy stopped by so I had he hold the inner nut part of the connectors while I tried to turn in the other part.. didnt work.. I have to cut back the insulation and the cardboard on the back of the carpet panel to get it started.. a bit more work to finish up Thanks guys
[Re: roadhazard]
#2036739
03/22/16 09:00 PM
03/22/16 09:00 PM
MR_P_BODY
Believe it or not I've had a fair amount of success applying silicone RTV around the post and battery case to seal it from escaping gasses that cause corrosion. Once the cable is connected it's undetectable.
That Fluid Film is nice stuff. That being said I don't want gooey greasy battery terminals if I can help it. I was thinking RTV on the post/case.. might try it also.. I just dont like the crap that builds up there
[Re: MR_P_BODY]
#2037055
03/23/16 11:52 AM
03/23/16 11:52 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
That Fluid Film is nice stuff. That being said I don't want gooey greasy battery terminals if I can help it. I was thinking RTV on the post/case.. might try it also.. I just dont like the crap that builds up there I used my old stand by Permatex Ultra Black
[Re: roadhazard]
#2037253
03/23/16 04:48 PM
03/23/16 04:48 PM
MR_P_BODY
I finished up another small job.. I wanted to install a power inverter so I could power my puter while driving.. mainly for DW but around here also while its learning... the inverter tucks in nice between the back wall of the cab and the main roll bar so its out of the way... then I used the plugs that Doug(DVW) gave me so I can unplug it easy for removal.. its a nice clean set up
