Re: which sump for lo deck A body
[Re: mopar dave]
#2035181
03/20/16 05:53 PM
03/20/16 05:53 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I used that pan in my 440 dart, revving to 6700 for over 5 yrs and i intend to use it with my low deck stroker as well. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mopar dave]
#2035480
03/21/16 12:45 AM
03/21/16 12:45 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The factory type pans are IIRC "187" and "499" part numbers. they have a feature that's not as deep, and more rounded to clear the idler arm.
[Re: AndyF]
#2159285
09/22/16 10:55 AM
09/22/16 10:55 AM
Posts: 567 Sth.IL
dare_dude
Sth.IL
Yep! Had to do that with my 440 source Pan. Also cut out and reboxed K frame.I had a little more of a problem because of girdle. (dropped things down a little more)
[Re: dare_dude]
#2159722
09/22/16 10:17 PM
09/22/16 10:17 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Milodon Road Race pan, low profile with great baffling. You MAY need to clearance the K-member, The k members are not very consistent in construction. The only downside of the Milodon pan is they aren't cheap, but neither are engines....
[Re: AndyF]
#2159733
09/22/16 10:30 PM
09/22/16 10:30 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have this pan for sale in the race section. It came out of a BB A-body car. The pan had to be modified to clear the idler arm. That is one thing to watch out for in an A body car, it the pan doesn't have that clearance then you'll need to be modify the pan. A 440source pan hit the K-frame significantly (B engine in stock position with AR motor plate) and I didn't feel like notching the K. I tried a Milodon center sump pan and it did fit (barely), but still bumped the steering linkage in the area shown. So I clearanced it with a BFH. Looks ugly but nobody can see it under there anyway! Although if it ever comes off again I'll have someone cut & weld a neat notch like Andy's
[Re: mopar dave]
#2160595
09/24/16 01:05 AM
09/24/16 01:05 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I am using the Milodon 7qt with external oiling. Part Number 30931. Engine is a low deck stroker, stock steering box and idler, QA1 upper and lower control arms. Factory 318 torsion bars... Lakewood scatter shield with Jerico 4-Speed..... -Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: Skeptic]
#2160718
09/24/16 10:41 AM
09/24/16 10:41 AM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Milodon Road Race pan, low profile with great baffling. You MAY need to clearance the K-member, The k members are not very consistent in construction. The only downside of the Milodon pan is they aren't cheap, but neither are engines.... Another vote for the road race pan. I went through 2 7 qt pans, 1 Milodon, 1 Moroso due to ground clearance issues (admittedly we live on a road that people with Jeeps comment on its condition). If I had bought the road race pan it would have cost the same as the total of the two pans plus I still had to bu the road race pan. This is on a 70 Road Runner so can not speak to K members, steering etc. Even on the B body it would have been easier to install from underneath with that pan but hopefully you install the engine on an irregular basis..... Once in no issues on the clearance front.
