which sump for lo deck A body #2033153
03/17/16 02:39 PM
03/17/16 02:39 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Which pan sump do i need for a lo deck in an 67 A body? seen a nice stefs aluminum pan in the for sale section.
Re: which sump for lo deck A body [Re: mopar dave] #2033691
03/18/16 11:45 AM
03/18/16 11:45 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Most center sump pans will work,but the distance from the front pan rail to the sump I think has to be 5". This means the oil pan for a E-body like the Milodon 6qt unit wont work.
Nautilus Racing-
Re: which sump for lo deck A body [Re: Chris2581] #2033758
03/18/16 01:44 PM
03/18/16 01:44 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks chris, just want i needed to know.
Re: which sump for lo deck A body [Re: mopar dave] #2033839
03/18/16 03:24 PM
03/18/16 03:24 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
You will need clearance for the idler arm also
Re: which sump for lo deck A body [Re: JAMESDART] #2033850
03/18/16 03:36 PM
03/18/16 03:36 PM
Mt Morris Michigan
Mt Morris Michigan
ok
Re: which sump for lo deck A body [Re: mopar dave] #2033868
03/18/16 03:49 PM
03/18/16 03:49 PM
I used a Mopar low profile 6 quart 1970/71 Hemi and 440 6 pak oil pan in my old Duster, I did slide the motor back one inch with elephant ears up front and I had to slot the stock V8 tranny mount to make it fit that way up I did need to grind a tiny little bit, around a 1/4 inch, off of the K member rear lip on the passenger side front edge that was near the oil pan corner sawzall I also slid the rear end forward one inch with ladder bars and coil overs while stretching the rear wheel wells so I could put a bigger rim and tires on it for the increase power thumbs That car was almost 50 % weight on the front and back with me in it boogie grin
Re: which sump for lo deck A body [Re: mopar dave] #2033872
03/18/16 03:55 PM
03/18/16 03:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If you have a choice among more than 1 that fits, you want:
1st: deepest "full" level and lowest pickup position
2nd: highest volume up to the pan rail (not just to the "full" level)
Boffin Emeritus
Re: which sump for lo deck A body [Re: polyspheric] #2033947
03/18/16 05:54 PM
03/18/16 05:54 PM
Mt Morris Michigan
Mt Morris Michigan
Can i get an off the shelf pan for this combo?
Re: which sump for lo deck A body [Re: mopar dave] #2033960
03/18/16 06:25 PM
03/18/16 06:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Moroso 8 ot pan fits,as does the Mopar 6 qt. Milodon has the pan that is a low profile,it fits too.I've used all 3 pans I've mentioned in a BB/A body car.
Nautilus Racing-
Re: which sump for lo deck A body [Re: Chris2581] #2034013
03/18/16 07:59 PM
03/18/16 07:59 PM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks again chris.
Re: which sump for lo deck A body [Re: mopar dave] #2034258
03/19/16 02:15 AM
03/19/16 02:15 AM
st.louis,mo.
dart games Online content
dart games  Online Content
st.louis,mo.
charliesoilpans.com will build you a pan if needed
Re: which sump for lo deck A body [Re: dart games] #2034290
03/19/16 03:16 AM
03/19/16 03:16 AM
Mt Morris Michigan
Mt Morris Michigan
moneys very tight right now with this build. starting from cratch sucks, so will be getting the moroso 8qt pan Chris mentioned. found it at jegs for $134. very affordable right now. thanks
Re: which sump for lo deck A body [Re: mopar dave] #2034612
03/19/16 06:36 PM
03/19/16 06:36 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same pan on Ebag from KMJ Performance...about 80 bucks...
Nautilus Racing-
Re: which sump for lo deck A body [Re: mopar dave] #2034667
03/19/16 08:37 PM
03/19/16 08:37 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What is your intended RPM ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: which sump for lo deck A body [Re: mopar dave] #2034677
03/19/16 08:55 PM
03/19/16 08:55 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
milidon oilpump single static pickup milidon low profile 7 quart oilpan 7000 rpm,s
1.39 9.85 - 137 mph
Re: which sump for lo deck A body [Re: Chris2581] #2034797
03/20/16 12:24 AM
03/20/16 12:24 AM
Mt Morris Michigan
Mt Morris Michigan
thanks chris. 6500rpm ceiling.
Re: which sump for lo deck A body [Re: mopar dave] #2034885
03/20/16 06:00 AM
03/20/16 06:00 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Dave you wouldnt happen to have a link to this pan would you?
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: which sump for lo deck A body [Re: turbo toad] #2034917
03/20/16 10:16 AM
03/20/16 10:16 AM
Mt Morris Michigan
Mt Morris Michigan
no but jegs had it. Ill see if i can find the part number.
Re: which sump for lo deck A body [Re: turbo toad] #2034944
03/20/16 11:19 AM
03/20/16 11:19 AM
Mt Morris Michigan
Mt Morris Michigan
been searching for that pan. Cannot find it. It was a black 8qt center sump bb moroso pan. Part number started with 500. Ill look harder when i get home.
Re: which sump for lo deck A body [Re: mopar dave] #2035079
03/20/16 02:44 PM
03/20/16 02:44 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
The only reason i ask is because the only advertised one i could find that was 8qt for a good price was this one
http://www.jegs.com/i/Mopar-Performance/312/P5007816/10002/-1
And was curious if this is the same one or if i was just overlooking it?
