Re: Pick a cam for the Imperial
[Re: Twostick]
#2032032
03/16/16 12:16 AM
03/16/16 12:16 AM
Posts: 4,669 Wichita
GY3
Wichita
Whatever you do put a degree wheel on it this time. You have 3 aftermarket components that that can be off ie cam and 2 gears. A degree off here or there on any or all parts can stack up to be the difference between it runs hard and it just runs.
Kevin Agree completely! Have you put a faster curve in the distributor? That's always done more to wake up soggy bottom ends than anything else on my Mopar vehicles. The 360 urged '75 Powerwagon was a slug down low until I recurved the distributor.
[Re: NANKET]
#2033747
03/18/16 01:15 PM
03/18/16 01:15 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Needs more compression, ditch the alum heads, go small chamber 1.60 exhaust valves. Still a band-aid.
Everything you have in that combo is wrong for what you want out of the car. Your alum heads are giving more away, More compression? Ya think? I'm not going to rebuild the engine on this thing unless it needs it. If that's becomes necessary the car will likely become yard art for a while. That also means that if I have to drop a bunch of money on the car it's going to be ignored for some time. The Eddy heads are on there because I had them and there was a problem with a factory head. I'm up to my ears in small projects and have a far more important car project I need to get to.
[Re: NANKET]
#2033776
03/18/16 02:16 PM
03/18/16 02:16 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Everything you have in that combo is wrong for what you want out of the car. Your alum heads are giving more away, This! Those alloy heads require more compression. I would get some iron heads and do minor tweaks. It would be a big plus. Build the Hotroddave super torquey mileage motor in the furture.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#2033797
03/18/16 02:32 PM
03/18/16 02:32 PM
feets
Senior Management
Senior Management
Irving, TX
Build the Hotroddave super torquey mileage motor in the furture. If I have to drop much money on this engine it will likely get replaced with something completely different.
[Re: WO23Coronet]
#2034047
03/18/16 08:48 PM
03/18/16 08:48 PM
Rug_Trucker
Yeah I don't see any problem with a better flowing aluminum head, that's a non issue. It's not like they're B1's with giant ports, they're Edelbrocks that (if I remember correctly) had a mild cleanup. The Imperial will never be a rocket ship as is, low compression, tall gears, tight convertor, 5000lbs+, its operating as it should. That's why a well built 440 will walk off and leave a Street Hemi because of the big ports on the street model. These heads may have too big of ports for the RPM range.
[Re: Rug_Trucker]
#2034663
03/19/16 08:31 PM
03/19/16 08:31 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
That's the same reason I'm not interested in the aftermarket aluminum heads for a 3.375 stroke 383.
68 Roadrunner. 383 4-spd. Beat up.
[Re: feets]
#2034847
03/20/16 02:28 AM
03/20/16 02:28 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
We always had great luck running the Crower 267/271 cam in the B motors with Rhoads lifters. At 5000' we were gaining a bunch of torque even in the big heavy cars. That cam in a Blues Brother Monaco with a 440 and it would lay rubber easily. I might even consider going up to the 271/284 especially with the Rhoads VMax lifters. You get the longer duration and higher lift and good vacuum at idle. I can imagine at 700' it should be a much more spirited ride.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Rug_Trucker]
#2034855
03/20/16 02:47 AM
03/20/16 02:47 AM
Posts: 4,254 Canada
WO23Coronet
Canada
Yeah I don't see any problem with a better flowing aluminum head, that's a non issue. It's not like they're B1's with giant ports, they're Edelbrocks that (if I remember correctly) had a mild cleanup. The Imperial will never be a rocket ship as is, low compression, tall gears, tight convertor, 5000lbs+, its operating as it should. That's why a well built 440 will walk off and leave a Street Hemi because of the big ports on the street model. These heads may have too big of ports for the RPM range. Big difference between Hemi port size and a 906 vs an Edelbrock rpm and a 906, apples and oranges. I think you guys are chasing your tails blaming the aluminum heads
