Re: Anyone have experience with 4.7 grand Cherokees?
[Re: MileHighDart]
#2032893
03/17/16 03:01 AM
03/17/16 03:01 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Don't waste your money....there is a reason that there is so many for sale...invest in a Hemi
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: MileHighDart]
#2032909
03/17/16 03:58 AM
03/17/16 03:58 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Mines been great 237k couple of water pumps, exhaust manifold gaskets and that's it. There's several hundred thousand 03 - 06 4.7's in Dakota/ durangos and jeeps still on the road. My quad Dakota pulled my demon on full trailer just fine.
[Re: MileHighDart]
#2033161
03/17/16 02:50 PM
03/17/16 02:50 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
its about 50-50 guys who have major issues and guys who like em. Not good odds in my book. I have 3 with bad engines sitting here, one I finnaly found a replacement for gonna cross my fingers and put it in, one I am gonna try a 5.7 swap, the third I am looking for a good used engine, not haveing any luck unless I want to spend $1500 plus and hope for the best. I have seen rockers fall off and not hurt anything, put em back then another falls off then another... if you are lucky you can keep putting em back, sometimes it gets trapped between the cam and valve and holds the valve open for the piston to kiss it. Sometimes it busts the head when the cam hits the misplaced rocker. The most common problem I see though is probably the head gasket, lots and lots of em, that problem snoballs real fast, the overheating (even a little) can let the valve seat fall out and reak havock on piston and block, the water in the oil can take out crank bearings real fast, most of the time the heads are warrped real bad (hard to tell if that caused the head gasket to leak or visaversa). Also seen tensioners fail and if your lucky the chain just rattles on start up, sometimes they jump and hit valves. They are better than a 2.7. We see a lot of failures in dodge engines ending in .7 the 2.7 3.7 4.7 and even the 5.7 hemi (usually only if overheated, the only non avoidable failure I see is the rods like to snap in perfectly maintained engines)and 6.7 cummins with injectors failing and pistons getting melted.
If you can find a 4.0 GC they are a much better rig.
[Re: HotRodDave]
#2033188
03/17/16 03:23 PM
03/17/16 03:23 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Buy a 2007 and up GC. Updated 4.7L w/ better mileage (2-3 mpg)and a ton more power.(Dual plug cyl head w/ poly chamber.) Engines are hyper sensitive to the condition of the oil.Use the best oil you can afford. 80% of issues are oil related. And yes I have experience with the 4.7L.
Leave the gun.......take the Cannoli's....Mike
[Re: MileHighDart]
#2033242
03/17/16 04:46 PM
03/17/16 04:46 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Looking at replacing my Nissan p/u with a used Grand Cherokee. Something in the 2003 - 2006 range. Lots of them have the 4.7 liter engine. Would it be suitable for pulling a decent sizes pop-up camper? Any common problems with the 4.7? I'm sure it would do a better job than my v6 Nissan. Or should I hold out for a 2005-06 with the Hemi? the 4.7 is a strong engine I loved our 99...until it just spit a rocker out the valve cover. It only had like 90k on it and it was very well maintained. Seems to be an issue with some. The tow truck driver said he has one his dad gave him w/ over 350k, no issues at all, original motor and trans.
