throwout bearings - 23 spline vs 18 spline
#2032178
03/16/16 05:35 AM
03/16/16 05:35 AM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
what is the difference between the 23 spline and 18 spline throuout bearings ? I assume that the 18 spline throuout bearing has a bigger bore size. If I switch from a 23 spline A833 to a 18 spline transmission, can I reuse the 23 spline throwout bearing and clutch fork or do both need to be bigger ? thanks in advance ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: throwout bearings - 23 spline vs 18 spline
[Re: docford]
#2032180
03/16/16 05:45 AM
03/16/16 05:45 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
23 spline is for 1.125" shaft the 18 is for a 1.187"
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: docford]
#2032210
03/16/16 09:43 AM
03/16/16 09:43 AM
docford
Munich, Bavaria
thanks for the reply :-) 0.052" is not much of a difference. Would both input shafts use the same bearing retainer sleeve or do these also have different diameters ?
[Re: docford]
#2032230
03/16/16 10:23 AM
03/16/16 10:23 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
The big one will wobble on a 23 spline.Summit gave me the wrong one once.Tried it on my 23 spline and no way would I use the hemi one.The sleeves are different as the 18 has to be bigger to fit the shaft.Rocky
Chrysler Firepower
[Re: docford]
#2032311
03/16/16 12:22 PM
03/16/16 12:22 PM
Posts: 5,166 CT
GTX MATT
CT
Clutch fork is the same, the bearing is different though as stated
