Detroit locker on the street ?
#2031039
03/14/16 05:04 PM
03/14/16 05:04 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Is it going to last longer than the 2yr old Eaton trutrac, that did it's best cone type impersonation, grinding itself to death to the point I had to beat an axle out of it ?
Re: Detroit locker on the street ?
[Re: JohnRR]
#2031055
03/14/16 05:24 PM
03/14/16 05:24 PM
Posts: 16,504 On the run…
BloFish
On the run…
I have been running one now for 5 years and have had no problems to speak of, granted, the miles are limited.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: JohnRR]
#2031059
03/14/16 05:26 PM
03/14/16 05:26 PM
Posts: 2,094 central texas
krautrock
central texas
@JOhnRR oh damn. how much power were you running through the trutrac and were you running it with sticky tires? i was thinking about getting one...
maybe that sways me towards a clutch diff or detroit locker
[Re: krautrock]
#2031069
03/14/16 05:59 PM
03/14/16 05:59 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I have been using mine on the street for about 12 years no issues whatsoever.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: JohnRR]
#2031133
03/14/16 07:40 PM
03/14/16 07:40 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I have not run one in a car, but have driven several long-term in 4x4 trucks. No complaints, most were lighter duty rigs but we never broke one. Not saying it isn't possible but I haven't heard many stories of failing them.
They will chirp the tires if you apply throttle in a turn, and you occasionally will get clunks too.
[Re: JohnRR]
#2031147
03/14/16 08:14 PM
03/14/16 08:14 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
They make a Detroit soft locker also that is supposed to be quieter....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Uncle Barry]
#2031280
03/14/16 11:25 PM
03/14/16 11:25 PM
Posts: 7,506 Az
Crizila
Az
I absolutely hate my locker. Shoves the front end so hard it feels like its about to break something. I run a 295/65 drag radial so that could be some of the problem. It makes a lot of banging and cracking noises too. Just not too street friendly in my opinion. Wouldn't even consider one in bad weather driving.
Fastest 300
[Re: JohnRR]
#2031286
03/14/16 11:30 PM
03/14/16 11:30 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
We had one in an old style Bronco. Horrible on the street, can't imagine a spool being much worse. Tires fighting and barking to get around a corner... Just too aggressive for my taste. Fantastic in the dirt, and I suppose at the track
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: JohnRR]
#2031303
03/14/16 11:46 PM
03/14/16 11:46 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Sounds like you may as well use a spool as already mentioned. I ran a spool for many many years on the street. I now have a stock posi and love it on the street but wouldn't trust it at a track.
[Re: JohnRR]
#2031309
03/15/16 12:01 AM
03/15/16 12:01 AM
R70RUNNER
Riverside, Ca
As I recall theres a technique to driving one especially making a rt hand turn. I was never good at it but it wasn't my vehicle. (Dads) Either come off the power before the wheels are turned and coast through it, or if you had to stop, stay back and release the brake and let the vehicle build a little momentum straight and not touch the gas until part way through the turn. The trick was to either unlock it by removing power or not applying power until it was turned. If it was under power going around the corner it would fight. I suppose a stick would be easier to manage than an automatic. The Bronco was auto.
[Re: JohnRR]
#2031320
03/15/16 12:14 AM
03/15/16 12:14 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Just put a spool in it. I have driven a car with a spool or back in the old days welded spider gears for 1000's of miles on the street and never had any issue rain or shine.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2031370
03/15/16 12:55 AM
03/15/16 12:55 AM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I run one in my stick shift Cuda. I never had any issues cornering. Only thing is shifting under power gives you a little "wiggle" due to unloading and loading quickly. Made me nervous at first but I've gotten used to it. :-)
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: D-50]
#2031511
03/15/16 10:25 AM
03/15/16 10:25 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Just put a spool in it. I have driven a car with a spool or back in the old days welded spider gears for 1000's of miles on the street and never had any issue rain or shine. Careful...you're gonna get piled on by the crowd that believes you'll die if you drive in the rain w/ a spool...read it on the all-knowing interwebs.
[Re: krautrock]
#2031613
03/15/16 01:01 PM
03/15/16 01:01 PM
JohnRR
U.S.S.A.
maybe that sways me towards a clutch diff or detroit locker Friends car that I am the crew of ... 2012 Mustang V6 that he races in a 12.5 index class ... slicks, 5 speed and 75HP shot of giggle gas, he launches it at somewhere around 4k rpm. It's his daily driver so he puts many thousands of street miles on it yearly. It has stock C clip axles and the side gears are thrust into the center of the unit, the gears are harder than the carrier and there is no thrust washer of any kind in between them. The drivers side was worse than the pass side , it raised a burr on both sides but it was so big on the left that it stopped the clipped end on of the axle from being slid in far enough to get it out. it too a combination of a chisel, a dremel with stones and steel cutters, and finally hammering the axle in both directions till I was able to get the clip out. I did a little research before recommending he go this route, but obviously not enough as I have since found info on line showing this exact issue back as far as 2011, and earlier with the 2 worm gear design. I wanted something that was not going to require yearly, or bi yearly rebuilds and since he drives it year round, including in the snow, a spool was not an option.
