Kickdown clip broke on my 71 Charger and can't find one??? #2030508
03/13/16 09:21 PM
03/13/16 09:21 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Hey guys needing some help here. Had a clip on our kickdown break on my 71 Charger and now I can not locate a replacement anywhere. Does anyone know if anyone makes just the clip? I will attach a pic of it below before it broke. It is the clip the holds the kickdown onto the pivot ball of the carb. You can see it here in the pic. ANY help would be greatly appreciated as it is the last thing holding us up on getting her done. Thanks! runaway
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2030510
03/13/16 09:22 PM
03/13/16 09:22 PM
Wahoo Nebr
Wahoo Nebr
Pic of it broken blush , This is what I need. Thanks
1969.5 A12 Bee EV2
1971 Charger RT
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2030520
03/13/16 09:37 PM
03/13/16 09:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Without knowing the ball/shaft diameters, check with Mr Gasket or Dorman/HELP/MotorMite line for a clip replacement, FYI I'll assume that you know to remove the clip, install the ball into the receiver, then clip it?, I hope it didn't break because you pressed the ball into the clip?
Mike
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2030880
03/14/16 01:34 PM
03/14/16 01:34 PM
Wahoo Nebr
Wahoo Nebr
Does anyone know where to get just the clip??
1969.5 A12 Bee EV2
1971 Charger RT
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2030915
03/14/16 02:12 PM
03/14/16 02:12 PM
None
71rm23 Offline
71rm23  Offline
None
Go to Doorman's web site and punch in the number, that Dayclona searched, it will come up. It has on it "where to buy". Punch in your zip and you should be good to go up
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: 71rm23] #2030924
03/14/16 02:22 PM
03/14/16 02:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Only place that has "just the clip" is Corvette Pacifica 1800-488-7671 PN# E10325 for a 1/4 ball stud $4.00
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2031053
03/14/16 05:21 PM
03/14/16 05:21 PM
Wahoo Nebr
Wahoo Nebr
Thanks!
1969.5 A12 Bee EV2
1971 Charger RT
Re: Kickdown clip broke on my 71 Charger and can't find one??? [Re: vette1986] #2032290
03/16/16 11:56 AM
03/16/16 11:56 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Those hands look familiar!!
