Keep breaking 3rd gear
#2030350
03/13/16 05:27 PM
03/13/16 05:27 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I have broke 3 transmissions in 2 years. They are 18 spline 833 4speeds. It is always the 3rd gear, on the countershaft. It usually does not hurt the 3rd drive gear. This last time it did thou. They are all in street cars, making about 720 hp/660 tq. I don't speed shift, or have sticky tires. It always happens when it hooks in 3rd gear. I know everybody is going to say get a Lenco, but I cant cut the cars. Is there anything I can do to help? Would the gear oil matter? I use 80/90 gear oil now. Is there anything you can do to the gears to strengthen them? I will be buying another countershaft, and drive gear tomorrow. Can you send them out for treatment? This is getting expensive, and the counter shafts are getting harder to find. Lastly, I see they make a Chinese countershaft ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) anybody have any luck with them? Harder to find originals anymore.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Keep breaking 3rd gear
[Re: MR_P_BODY]
#2030364
03/13/16 05:52 PM
03/13/16 05:52 PM
Old School
Virginia Beach, VA
Are you shearing off the teeth on the counter or just tearing them up(slowly eating them off) Hey Mr P body. They just keep breaking the teeth off. The rest of the trans looks very good.I don't think it is a wear problem. Would a thicker gear oil help, maybe 140 wt? this is the pic or the damage this time...
[Re: Old School]
#2030366
03/13/16 05:57 PM
03/13/16 05:57 PM
Old School
Virginia Beach, VA
this is what it usually looks like. this last time was the only time it broke the drive gear.....
[Re: Old School]
#2030368
03/13/16 05:57 PM
03/13/16 05:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you shearing off the teeth on the counter or just tearing them up(slowly eating them off) Hey Mr P body. They just keep breaking the teeth off. The rest of the trans looks very good.I don't think it is a wear problem. Would a thicker gear oil help, maybe 140 wt? this is the pic or the damage this time... It could but since your on your 3rd set.. I doubt it but it MIGHT act as a better cushion... I find it hard that your breaking 3rd on street tires.. but then you say... when it hooks(spinning) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2030372
03/13/16 06:03 PM
03/13/16 06:03 PM
Old School
Virginia Beach, VA
It spins in the lower part of 3rd. I will lift a little, then roll back in. That stops the spin, but that is when the trans breaks. The last few times, when I would lift, I would stab it back to the floor. That was when it would seem to want to break the most. I have since started to ease back in, that has helped a lot.... But still breaking them...
[Re: Old School]
#2030376
03/13/16 06:06 PM
03/13/16 06:06 PM
Old School
Virginia Beach, VA
This last time was in my 68 charger. it weighs 4000 with me in it. the other cars are 70 cuda converts. they weigh 3800 with me in them.
[Re: 68shifter]
#2030378
03/13/16 06:08 PM
03/13/16 06:08 PM
Old School
Virginia Beach, VA
Deflection. At that power you're literally driving the gears apart. If the 833 had a 2-3 bearing support like most aftermarket stuff it would help a lot, but then gear size would probably become the next issue.
I used cryo, mikronite, three different styles of cases and new/used gears/counter shafts. Either drop your power level or get a different trans. I put lencos right there with auto's.lol
There's nothing you can't put back if you put a g-force or jerico in it. Good luck. I don't mind cutting sheet metal, just don't want to cut anything structural.
[Re: Old School]
#2030386
03/13/16 06:17 PM
03/13/16 06:17 PM
MR_P_BODY
The gear is brittle already so you dont want to add more hardness.. if you wanted to do some R&D you could take some heat treat out of it.. but you have to get the base rockwell C on the gear your using then try a couple of rockwell C less EDIT I would bet right now its 60-61 rockwell C
[Re: Old School]
#2030396
03/13/16 06:34 PM
03/13/16 06:34 PM
Posts: 1,169 MI
68shifter
MI
Are you shearing off the teeth on the counter or just tearing them up(slowly eating them off) Hey Mr P body. They just keep breaking the teeth off. The rest of the trans looks very good.I don't think it is a wear problem. Would a thicker gear oil help, maybe 140 wt? this is the pic or the damage this time... Sucks to see your breakage. I've got 4 paperweights just like that. The one thing you could be doing, it sounds like, is when the car spins your unloading then reloading and slamming everything back together. Thicker gear oil might help, but I bet you keep breaking them. The worst thing you might have to modify on an e body is the upper trans crossmember. This will be least with the previous two trans, and to put a Lenco or Nash will require quite a bit of modification. If you change your driving style it sounds like will be the best bet if you want to keep an 833. Or throw away two plug wires.
[Re: 68shifter]
#2030429
03/13/16 07:24 PM
03/13/16 07:24 PM
Old School
Virginia Beach, VA
thanks 68shifter. I am going to call about these trans tomorrow. If they hold, it will be cheaper in the long run...
[Re: Old School]
#2030440
03/13/16 07:34 PM
03/13/16 07:34 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Contact Liberty trans, or Jamie Passon...they might be able to help
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Old School]
#2030441
03/13/16 07:35 PM
03/13/16 07:35 PM
MR_P_BODY
I assume your using a single disk clutch.. might look into a dual disk for a little slip.. years ago when I was racing a 833 I made a rock crusher and had to soften up the gear.. I pulled 2 rockwell C out of it with the advise of some old racers.. but being your a street car you dont want a crusher EDIT Your issue is the letting off and hitting it..and it bits
[Re: MR_P_BODY]
#2030448
03/13/16 07:42 PM
03/13/16 07:42 PM
Old School
Virginia Beach, VA
I assume your using a single disk clutch.. might look into a dual disk for a little slip.. years ago when I was racing a 833 I made a rock crusher and had to soften up the gear.. I pulled 2 rockwell C out of it with the advise of some old racers.. but being your a street car you dont want a crusher All of them have a McLeod dual disc clutch.....
[Re: MR_P_BODY]
#2030458
03/13/16 07:51 PM
03/13/16 07:51 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
My last 833 trans had cryo softened gears from Liberty's and they lasted over 60 passes. I will note though when I put that trans in I also changed my clutch with an adjustable unit with a bronze disc.It allowed just enough slippage to keep that transmission in one piece and it was still in use when I installed the Richmond 5-speed. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Old School]
#2030462
03/13/16 07:56 PM
03/13/16 07:56 PM
fourgearsavoy
Rittman Ohio
I assume your using a single disk clutch.. might look into a dual disk for a little slip.. years ago when I was racing a 833 I made a rock crusher and had to soften up the gear.. I pulled 2 rockwell C out of it with the advise of some old racers.. but being your a street car you dont want a crusher All of them have a McLeod dual disc clutch..... The last 833 I broke was using a Mcleod Street Twin. That clutch is a ZERO slip unit and will continue to eat factory transmissions. I sold mine and went to a single adjustable unit and life was good again. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Old School]
#2030514
03/13/16 09:28 PM
03/13/16 09:28 PM
Old School
Virginia Beach, VA
I was reading about the Legend SST 5 speed transmission. Says it will handle 700 ftlbs. Looks like a really nice piece! Anybody try one yet?
[Re: Old School]
#2030564
03/13/16 10:24 PM
03/13/16 10:24 PM
fourgearsavoy
Rittman Ohio
The hidden costs will add up quick when using that transmission and you better pray it doesn't break because some parts may be hard to find ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) As posted above the Richmond is strong but it takes some cutting to fit with a custom made crossmember. A GF5R is a nice box from G-force ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
