Page 3 of 3 1 2 3
Re: ATF in TF727? [Re: fed] #2028930
03/11/16 01:10 AM
03/11/16 01:10 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Excellent, the low viscosity Hyguard is what I have almost a full drum of. Hopefully it works better in a 727 then it does in a 9520
Re: ATF in TF727? [Re: fed] #2028931
03/11/16 01:12 AM
03/11/16 01:12 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Some of the big horsepower turbo cars will smoke the regular trans fluid in one pass and some guys used to change it every pass. The Hy-Guard is VERY resistant to heat.
Only bad thing, is that it's hard to see on the stick. Easily fixed by adding some color dye. I won't say who, but will say that SEVERAL of the trick "race fluids" are simply Hy-Guard with dye. How do I know? Because I have seen them pump it from 55 gal drums into their bottles........LOL!!!
Re: ATF in TF727? [Re: fed] #2028935
03/11/16 01:21 AM
03/11/16 01:21 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Think I'll pick up a gallon of each, the ATF that's in my converter will give enough color to see it on the dip stick.
Re: ATF in TF727? [Re: justinp61] #2028956
03/11/16 01:52 AM
03/11/16 01:52 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Agree, while the engine is out I will be making the switch to Hy-gard
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: ATF in TF727? [Re: slammedR/T] #2028974
03/11/16 02:18 AM
03/11/16 02:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I tried it once to see if I could get the
conv to stall higher... it didnt help mine
so I swapped back... but after reading more
info I might have used the wrong one
wave
Re: ATF in TF727? [Re: Monte_Smith] #2029015
03/11/16 04:41 AM
03/11/16 04:41 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have heard for 40 years that B&M Trick Shift is just Type F with blue dye in it. shruggy
Re: ATF in TF727? [Re: slantzilla] #2029023
03/11/16 05:53 AM
03/11/16 05:53 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Hey Monte according to the table, the reg Hygard handles heat better than the lo viscosity one....
Which do you feel would be better in a street /strip application 727 with a decent cooler and with 5K stall ?
Re: ATF in TF727? [Re: Monte_Smith] #2029080
03/11/16 11:06 AM
03/11/16 11:06 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Monty JD lists five hydraulic fluids. Which one do you you run?
Most use Hy-Guard or the Low Viscocity Hy-Guard. The Low Viscosity is a direct swap for most ATFs, except if you read the standards is MUCH more durable and maintains viscosity better at higher temps and that's what we WANT.
I would suggest the low viscosity for anybody wanting to swap.
We have run regular Hy-Guard and a lot of guys with Bruno's and Lenco Drives use this. The regular Hy-Guard will generally tighter your converter up about 200-300 on the stall.
Thanks Monty. thumbs
Re: ATF in TF727? [Re: Monte_Smith] #2029090
03/11/16 11:27 AM
03/11/16 11:27 AM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
I recently bought a converter from PTC, so at the same time I bought their Trans fluid to put in my fresh build 727. Their fluid appears to be some type of hyd fluid also.
1971 BS23H1B
Re: ATF in TF727? [Re: tx9cuda] #2029178
03/11/16 01:40 PM
03/11/16 01:40 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You would be right
Re: ATF in TF727? [Re: MR_P_BODY] #2029226
03/11/16 03:19 PM
03/11/16 03:19 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Originally Posted By MR_P_BODY
The one reason I run the type F is the guys
in the trans lab at Chrysler... I had plenty
of friends in there and asked this question
when I started racing... ALL of them said F
so I did
From a factory race bulletin.
Re: ATF in TF727? [Re: fed] #2029386
03/11/16 08:21 PM
03/11/16 08:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Picked up some Hy-Gard today, the Low Viscosity was $16 per gallon and the regular was $17.50.
Re: ATF in TF727? [Re: fed] #2029400
03/11/16 08:37 PM
03/11/16 08:37 PM
slammedR/T Offline
slammedR/T  Offline
Ordered some hy-gard low viscosity last night, $13.55 a gallon jug, so I got three gallons on the way smile
racemagnum
Re: ATF in TF727? [Re: fed] #2029409
03/11/16 08:56 PM
03/11/16 08:56 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Damn.......it's an epidemic.....LOL!!! Careful now guys, too much of this and you will have to turn in your "I'm a REAL Mopar guy buttons".......LMFAO!!!!
Re: ATF in TF727? [Re: fed] #2029420
03/11/16 09:18 PM
03/11/16 09:18 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
If you buy 4 drums of it, it will cost around $11 Canadian and they will deliver it to your yard!
Don't worry about losing your Mopar status, John Deere also overcharges to put their name and green paint on stuff so its pretty much the same
Re: ATF in TF727? [Re: fed] #2029426
03/11/16 09:28 PM
03/11/16 09:28 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Question, I talked to rossler a while ago, he told my about the Hyguard, BUT he told me it might slow the car. (He said the engine should make 1500 or more to use the Hyguard) I tried it and did not really see a change. I use type f as per rossler site. I didn't know it was available in diff viscosity. Maybe I should try the lighter one ?
....BAD A$$ STREET CAR.....
Re: ATF in TF727? [Re: Monte_Smith] #2029597
03/12/16 01:53 AM
03/12/16 01:53 AM
slammedR/T Offline
slammedR/T  Offline
I have a modern Dakota truck, I'm not considered a real Mopar guy anyway laugh2
racemagnum
Page 3 of 3 1 2 3
