Re: 440 intake on a 400
[Re: Street Monkies]
#2029043
03/11/16 09:44 AM
03/11/16 09:44 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I don't know if you can. You might end up rewelding the flanges on the bottom of the runners. That's a lot of metal to remove. Unless you put it on a raised port head like mentioned.
[image][/image]
[Re: B G Racing]
#2029119
03/11/16 12:08 PM
03/11/16 12:08 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
The valley plate at the china wall of an RB is about a solid inch wider than a B, so you'd need a pretty thick mating flange on both sides to start with. My gut would say probably not unless you had deep pockets to weld up the flanges.
There was a super stock 383 car in the early 80's where the guy used a much modded SB Chevy manifold on it, can't remember his name though and I would like to see how he accounted for the differences in bore spacing and port alignment, but apparently he successfully worked it out.
I have a 337 RB on my 400B/517 Stroker... but (as stated) it's on a set of the Chapman Stage VI's
#2029142
03/11/16 12:48 PM
03/11/16 12:48 PM
Posts: 8,946 Holly/MI
Dean_Kuzluzski
Holly/MI
Not dimensionally a good forseeable venture. The intake surface would be nearly gone.
[Re: cudaman1969]
#2029373
03/11/16 07:53 PM
03/11/16 07:53 PM
dogdays
Wize, there probably were 1.5" thick spacers between the SBC intake and the heads. You can move quite a bit in that distance.
R.
#2029556
03/12/16 12:47 AM
03/12/16 12:47 AM
Posts: 5,160 Texas
dannysbee
Texas
I own a weiand ss six pack that has been modified for a low block and two fours.
Getting old just means you were smarter than some and luckier than others.
[Re: Moparteacher]
#2029714
03/12/16 12:16 PM
03/12/16 12:16 PM
Posts: 5,160 Texas
dannysbee
Texas
I don't but I'll take one and post it.
[Re: Streetwize]
#2030211
03/13/16 01:14 PM
03/13/16 01:14 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
There was a super stock 383 car in the early 80's where the guy used a much modded SB Chevy manifold on it, can't remember his name Dave & Greg Smith, the Pro Trans guys.
[Re: cudaman1969]
#2030239
03/13/16 02:09 PM
03/13/16 02:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not sure if it works the same way but when I put the 383 intake on the high block I used a 1 inch spacer to allow the bolts to line up. Maybe as it gets closer to the crank that dimension gets smaller. It does.. thats why you have to cut the intake surface when you cut the head so the intake will bolt back on
