how to test a stock voltage limiter out of the car
#2028673
03/10/16 06:37 PM
03/10/16 06:37 PM
Posts: 12,216 NO RUST IN AZ!!!
azmopar
NO RUST IN AZ!!!
is there a way to test a stock voltage limiter out of the car and not attached to the dash? its the 3 prong style
70 Challenger Convertible 340 six pak CLONE? 70 Duster real FM3 car 65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: how to test a stock voltage limiter out of the car
[Re: stumpy]
#2028714
03/10/16 07:27 PM
03/10/16 07:27 PM
azmopar
NO RUST IN AZ!!!
Hook up the ground the 12v in and check the output with a VOM. ok but which post is which the one soldered to the outside o the case I believe is ground one is marked IGN the 3rd isn't marked at all
#NONIKESEVER
[Re: stumpy]
#2028733
03/10/16 07:48 PM
03/10/16 07:48 PM
azmopar
NO RUST IN AZ!!!
The ground is the one soldered to the case. the one marked ign is 12v in and the unmarked is the output and will be fluctuating voltage. ok thanks ill give that a try
#NONIKESEVER
[Re: azmopar]
#2028754
03/10/16 08:23 PM
03/10/16 08:23 PM
Posts: 199 NC
1970A66
NC
