Re: New Passon Performance 5 Speed update
[Re: JamiePasson]
#2015853
02/20/16 02:07 AM
02/20/16 02:07 AM
Posts: 4,719 Star Idaho
67vertman
Star Idaho
Great to hear that they are starting to get them out. I am 244 on the list, and thanks to you one step closer.
My Monster are real!
Living within your means makes life pretty easy.
[Re: JamiePasson]
#2028853
03/10/16 10:55 PM
03/10/16 10:55 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
It's good that after all these years. Some are getting out the door If I was to spend money on a new stick tranny. It would be the 6 speed like in our hellcat After seeing vid of a M6 (6 speed) cat put 1021 hp to the back wheels There is no doubt that it would Handel anything I will throw at it And it has a extra gear
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: JamiePasson]
#2029411
03/11/16 08:58 PM
03/11/16 08:58 PM
Posts: 237 USA
Grizzly69
USA
So...Without trying to wade through 100 + pages of this thread... Has it been revealed somewhere the actual price of this transmission ? Is there an entire set-up available ? I mean everything from the back of the crankshaft to the driveshaft, pedals, hump, shifter E-V-E-R-Y-T-H-I-N-G ? '69 Charger...472 Hemi
[Re: JamiePasson]
#2029650
03/12/16 03:49 AM
03/12/16 03:49 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Trans is 4795ish last time I looked, everything comes with it to install this trans in a manual car already (shifter/linkage). If you are converting an auto, you can still source the parts but they are not part of the regular kit. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Grizzly69]
#2029784
03/12/16 02:25 PM
03/12/16 02:25 PM
Posts: 4,179 California
mickm
California
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ? go to www.passonperformance.com, i believe he has conversion kits listed there.
[Re: Grizzly69]
#2029802
03/12/16 03:08 PM
03/12/16 03:08 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ? Pretty sure it's around $5k just the trans. complete conversion kits...I think you can find a lot of parts used. I think the auto-x-member will work w/this trans. Just get a big-block bellhousing, pedals, TO bearing, clutch just about anywhere. Then there's the hump you have to weld in.
[Re: Grizzly69]
#2029813
03/12/16 03:39 PM
03/12/16 03:39 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ? Call the guy. Hes good at answering the phone. Or send an email directly to him. He's pretty busy and doesn't get on here everyday to check this thread. There isn't just one set price as you can pick multiple options when doing a conversion.
[Re: mickm]
#2029833
03/12/16 04:31 PM
03/12/16 04:31 PM
Posts: 237 USA
Grizzly69
USA
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ? go to www.passonperformance.com, i believe he has conversion kits listed there. Did that. The coversion kits I saw there were for the four speed transmissions... About $4000 trans and all. So...in the five plus years this thread has been running, has anybody here actually completed a conversion from an automatic on a 69 B body? Is everything available from one source (Passon)?
[Re: Grizzly69]
#2029961
03/12/16 09:48 PM
03/12/16 09:48 PM
mickm
California
So...The cost of the entire set up to convert a 69 B body With a 472 Hemi from an automatic is how much ? go to www.passonperformance.com, i believe he has conversion kits listed there. Did that. The coversion kits I saw there were for the four speed transmissions... About $4000 trans and all. So...in the five plus years this thread has been running, has anybody here actually completed a conversion from an automatic on a 69 B body? Is everything available from one source (Passon)? that's the whole point of this transmission, that it is a 100% bolt in replacement for an A833. so every single piece you need to do a conversion will be the same regardless of whether you using a stock A833 or jamie's new A855. i haven't checked his site, but i'm sure he has a kit for all the parts minus the trans. if not, just email or ask him.
[Re: JamiePasson]
#2040294
03/28/16 09:20 AM
03/28/16 09:20 AM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
Hi Andy ,
Question : If placing an order online for your nice 5 speed. What would the "real world" delivery time be?
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
[Re: JamiePasson]
#2055882
04/17/16 12:58 AM
04/17/16 12:58 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
That extra gear is more reason I like the 6 speed like in the hellcat. They been holding up to over 100 hp to the back wheels in a 4500# car
