Re: Subframe Connectors w/ Roll Bar Install? [Re: dvw] #2027946
03/09/16 04:31 PM
03/09/16 04:31 PM
Here
jcc Offline
jcc  Offline
Here
Here is one of my in process solutions. Roll bar kicker will tie into rear most portion of rear SFC extender. Main SFC are 2.5" Sq .083". Car is a /6, other crossmembers are to securely tie in Sebring Seats w/integral seat/shoulder belt. Battery goes in hole. grin
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Subframe Connectors w/ Roll Bar Install? [Re: polyspheric] #2028010
03/09/16 06:12 PM
03/09/16 06:12 PM
Here
jcc Offline
jcc  Offline
Here
Originally Posted By polyspheric
IMHO the optimum height of the connector is a function of how much power, how much traction, and the wheelbase (longer = more flex).
On paper, 2" wide X 3" tall is much more rigid than 2 X 2 (over 2-1/2 times), the question is "how much is enough"?
I wonder if anyone has done a specific size install (2 X 3 etc.) and tried to jack up the left front, and measured how far off the ground the right front went up vs. another size?
Obviously, at some point the connector's stiffness exceeds that of the remainder of the chassis, and the right front will come up simultaneously.
As valid as your points are, aren't you intertwining beam strength with torsional strength above? And my reasoning why my latest iteration above, used 2.5 Sq.
Re: Subframe Connectors w/ Roll Bar Install? [Re: JonsGottaDusta] #2030133
03/13/16 06:29 AM
03/13/16 06:29 AM
san diego
JonsGottaDusta Offline OP
san diego
Thanks to everyone for contributing such amazing input to this thread. I'll likely be going to 2x2 route this week and will keep you updated on the project. Thank you!
Jon
