727 or 904 converter? #2025758
03/06/16 03:18 PM
03/06/16 03:18 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
How do you ID a torque converter to determine if it's for a 727 or a 904 trans?
Re: 727 or 904 converter? [Re: rarefish] #2025791
03/06/16 04:44 PM
03/06/16 04:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
IIRC the 727's keyed imput "lug" is blush 1.875" in diameter, the 904's is smaller.
Re: 727 or 904 converter? [Re: rarefish] #2025798
03/06/16 05:08 PM
03/06/16 05:08 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I have read where the spline count is different between the two. I'm wondering if that is also away to ID them.
Re: 727 or 904 converter? [Re: rarefish] #2025806
03/06/16 05:31 PM
03/06/16 05:31 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
The 727 converter snout is 1.875" in diameter and the 904 converter snout is 1.5".
Re: 727 or 904 converter? [Re: rarefish] #2025809
03/06/16 05:35 PM
03/06/16 05:35 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Diameters and spline count in this thread:
http://www.forabodiesonly.com/mopar/showthread.php?t=332348
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 727 or 904 converter? [Re: rarefish] #2025934
03/06/16 08:27 PM
03/06/16 08:27 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Using the snout diameter method. I find that it is 1.875" dia. What I have is a 727 conveter and I was thinking that it was a 904 one.
Thanks...
Re: 727 or 904 converter? [Re: rarefish] #2025941
03/06/16 08:35 PM
03/06/16 08:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you don't have anything to measure with, count the ring gear teeth...727 has 130, 904 has 122. (except for the '60-'61)
Re: 727 or 904 converter? [Re: rarefish] #2034394
03/19/16 12:07 PM
03/19/16 12:07 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I have rechecked all of the measurements on my unknown converter and everything is pointing to a 727 converter. 130 teeth, 1.875" snout etc. but when counting the splines inside. I see that there are two sets of them. I get 27 splines on the top set and 24 splines on the bottom or inner set.
I see on the above link that the spline count for the 1967 and later 727 have 24 splines so counting the inner set gives me that.
Does that sound right as the inner set being the one to count?
Re: 727 or 904 converter? [Re: rarefish] #2034598
03/19/16 06:20 PM
03/19/16 06:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the outer splines (reaction shaft) were the same from day one to the end of production...only the input shaft (inner) splines changed over the years
Re: 727 or 904 converter? [Re: rarefish] #2034624
03/19/16 06:58 PM
03/19/16 06:58 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks, John. I knew that you would come through on this....
