Intake air temp
#2025669
03/06/16 01:00 PM
03/06/16 01:00 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
is there a particular temperature inside the intake where you start loosing power? My roots deal is is seeing temps maxing so far at 205* water meth system is in the bucket list,but I would like to maximize what I have before any changes or additions. Right now I use stock iron heads with a good valve job.
Re: Intake air temp
[Re: hemi-itis]
#2026376
03/07/16 12:08 PM
03/07/16 12:08 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I am curious what your intake temps will do once you get the exhaust opened up.
68 Barracuda Formula S 340
Re: Intake air temp
[Re: DaytonaTurbo]
#2026405
03/07/16 12:42 PM
03/07/16 12:42 PM
Posts: 7,506 Az
Crizila
Az
I run a Snow water / alcohol system on my Pro-Charger blow through system. Besides the kit coming with 3 nozzle sizes, it has 2 adjustable pots on the controller to control when the water pump turns on and max water pump output at max boost ( I think it goes to 19 psi. ) I have no idea how accurate it is, but it does give you some adjustment. I have the pump turn on at 5 psi and max flow at 19 psi and I use the middle size nozzle. I think there is some "starting point" info in their literature. It's still a guess, and if you guess wrong, bad things can happen.
Fastest 300
Re: Intake air temp
[Re: hemi-itis]
#2027178
03/08/16 01:26 PM
03/08/16 01:26 PM
Posts: 4,213 New York
polyspheric
New York
Below ambient, if you can get it.
Boffin Emeritus
