Re: Drag Week 2016, who is in?
[Re: JERICOGTX]
#2031689
03/15/16 02:58 PM
03/15/16 02:58 PM
Posts: 200 AB
Efidart
AB
In again, registration was extremely simple to get in like it is every year.
Either you register and do it or you just talk about it...
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#2031699
03/15/16 03:13 PM
03/15/16 03:13 PM
Posts: 760 Canada
CTD5.9
Canada
Either you register and do it or you just talk about it... any big changes for you? Hopefully the dingle balls are still holding in and the glovebox stays closed.
[Re: JERICOGTX]
#2031701
03/15/16 03:22 PM
03/15/16 03:22 PM
Posts: 200 AB
Efidart
AB
Might reinforce the dingle balls this year...
As for the glovebox, I think I'm going to try and take 100 lbs out of it. Haven't ever looked close to take weight out of it so why not, lots of easy stuff to lighten with very little effort.
Extreme Automatics stepped up and are providing me with a 2 speed TH400 big shaft trans which will solve the trans problems. Part that broke was a Coan piece so it should make it pretty much bullet proof now.
Joe @ ProTorque also is helping me out on an EV1 torque converter so the car will not drive through the converter like it did last year.
Also need bigger injectors as I maxed the 200 LB Morans and some new fuel pumps as those are done as well.
Should be a good year as I can get a lot of testing and racing in before Drag Week this year.
[Re: Efidart]
#2031849
03/15/16 07:58 PM
03/15/16 07:58 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Either you register and do it or you just talk about it... Seems to be a trend with a few - I just hope they aren't taking spots away from people that actually intended on going.
[Re: JERICOGTX]
#2033007
03/17/16 11:30 AM
03/17/16 11:30 AM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
I added to wait list. If nothing else I'll be at Indy. Surely I can reassemble this engine by then, 😁
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2033030
03/17/16 11:47 AM
03/17/16 11:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I added to wait list. If nothing else I'll be at Indy. Surely I can reassemble this engine by then, 😁 Thats all I'm doing.. on the waiting list(I think) and I'll show up.. even if I dont get in, I'll drive along
[Re: JERICOGTX]
#2033174
03/17/16 03:04 PM
03/17/16 03:04 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I did not sign up this year. I was out of town on registration day (racing our Junkyard Wars car) and I'm not sure this will be a good year for me to be away from work in September. That could always change though.
My buddy Casey Cunningham has proposed that if we do end up going, we should just follow the route and have a good time. Sounds tempting.
Well see.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: JERICOGTX]
#2033541
03/18/16 12:56 AM
03/18/16 12:56 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Boone and I had early invites, so we felt obligated. Dale and Darren signed up as well. I didn't enter Rachael in a second car, but we will keep our options open. James Gilliland signed up in my old Challenger racecar, and that is a priority for Dale.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MR_P_BODY]
#2033553
03/18/16 01:11 AM
03/18/16 01:11 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
In. Since DW15, my car has lost 140lbs. Coil over conversion in the front. New rack and pinion, tie rod heims and brakes in the front. Going CRT 904. 8" Lenny special. Been running the 9 that was behind my 493. Changed gears...again. I have gears in stock now. Crusader valved Viking shocks for the rear. Cage was certed after DW so I just need to get car back together and get a license for sub 10s.
Pretty proud, all that I have done since DW only spent net about $1k so far. Also if I can get the time to finish porting my Apache Heads they will be on there too
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Dragula]
#2033991
03/18/16 07:28 PM
03/18/16 07:28 PM
MR_P_BODY
I was running my junk today to see how it shifted and was very happy with it... now I need to get some miles on it... it was a bit slow on the down shift but wasnt all that bad.. I think I have some high expectations n how it should shift(sure isnt like the race car) but in manual mode it did what I wanted.. in auto mode it did what I wanted.... I'm happy EDIT Of course I couldnt get away free from problems on this POS.. as I was pulling into the driveway the top radiator hose blew off.. that hose has been a bit of a issue.. I'm changing it now
[Re: Dragula]
#2034144
03/18/16 11:16 PM
03/18/16 11:16 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I gave up when they discontinued the street legal drag radial tires....Only the pro will be available it seems. I wanted to run a set of 315's that had tread on them so I don't need to have a trailer....Heck it looks like they even discontinued the prostreet tires I ran from M&T, So I will be going with Hoosier QTP this year, and those are no good in any rain. The 605 is almost back togather as I type this. I think I might take a tire groover to mine in an effort to make it less sketchy in the rain... The other option was ponying up $$$ for new wheels and street tires. Options are limited when you're looking for 30" tall tires.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: JERICOGTX]
#2034230
03/19/16 01:15 AM
03/19/16 01:15 AM
MoparBilly
Phoenix, AZ
Leaving Cordova this year. To ksj, cruising around on street tires, this qualifies as "No rain". When you are pulling a trailer with straight axle truck on a spool and M/T ET Streets...this was thirty minutes of pure terror!
[Re: JERICOGTX]
#2034331
03/19/16 09:09 AM
03/19/16 09:09 AM
Posts: 1,629 pa
572charger
pa
im in !!!! went last year with my girl and her car turbo regal we had a blast after hurting the good motor on the dyno 10 days before dw i put togethr a back up v6 motor put it in the car and on the trailer , finished it in the tech lanes sunday morning never drove it once till monday after we raced !!!! she now holds the record for 10 yrs of drag week quickest buick and quickest v-6 now we will both go this year if all works out !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dragula]
#2034389
03/19/16 11:57 AM
03/19/16 11:57 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I gave up when they discontinued the street legal drag radial tires....Only the pro will be available it seems. I wanted to run a set of 315's that had tread on them so I don't need to have a trailer....Heck it looks like they even discontinued the prostreet tires I ran from M&T, So I will be going with Hoosier QTP this year, and those are no good in any rain. The 605 is almost back togather as I type this. You can still buy the old style 315, it discontinued but there still in stock.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 572charger]
#2034425
03/19/16 01:01 PM
03/19/16 01:01 PM
Posts: 10,041 MN
JERICOGTX
MN
im in !!!! went last year with my girl and her car turbo regal we had a blast after hurting the good motor on the dyno 10 days before dw i put togethr a back up v6 motor put it in the car and on the trailer , finished it in the tech lanes sunday morning never drove it once till monday after we raced !!!! she now holds the record for 10 yrs of drag week quickest buick and quickest v-6 now we will both go this year if all works out !!! Hope the Charger is at DW this year Jim! See you and Lisa in September.
69 GTX
68 Road Runner
