Re: Axle strength as a function of spline count
[Re: polyspheric]
#2024164
03/03/16 11:39 PM
03/03/16 11:39 PM
Posts: 22,696 Bitopia
jcc
Bitopia
So isn't root diameter a better/more accurate indicator then spline count, and harder to know, and why the focus is usually on spline counts? But then why is it to anyone's advantage to cut more splines, if strength is only marginally increased if root diameter is almost the same, ie trans inputs, pinion yokes, etc?
[Re: polyspheric]
#2024273
03/04/16 03:04 AM
03/04/16 03:04 AM
Posts: 4,206 New York
polyspheric
New York
The point is that they don't just cut more splines, the diameter is always increased proportionate to the spline count, and the carrier's spline count must (duh) also match. With the same spline contour, a 40 spline axle is 33% thicker than a 30 spline, etc.
Boffin Emeritus
[Re: polyspheric]
#2024460
03/04/16 02:12 PM
03/04/16 02:12 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The contour of axle splines, at least on the stuff were talking about, are pretty consistent between manufacturers. Mark Williams uses a little different shape, but for the most part, a 40 spline axle is pretty much the same size across the board. Larger diameter = more splines. When discussing strength and resistance to twisting and/or breaking, other things have to be considered. Material and heat treat methods, machining methods (radii vs. sharp corners, etc.), solid vs. gun drilled and many other details. They aren't all made with the same stuff and the same way.
[Re: Monte_Smith]
#2024536
03/04/16 04:12 PM
03/04/16 04:12 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Mark Williams splines are rolled in , most others are cut. A Mark Williams axle will fit in about any 40 spline spool, but the opposite is not true. Meaning most other axles won't fit MW spools MW is top notch. I realize it's a less costly process to cut splines & it also surprises me that others wouldn't have a rolled spline axles, which are stronger.
72 Plymouth Roadrunner 11.08@123.25
