Re: carnage at the dyno
[Re: HotRodDave]
#2022952
03/02/16 01:14 AM
03/02/16 01:14 AM
Posts: 4,457 Washington
madscientist
Washington
I been studying hard the oiling in my stroker I am building and it seems the full groove would help the rod bearings live longer because they have access to pressurized oil when the cylinder pressure is highest. The 1/2 groove only sends pressurized oil to the rod on the bottom half of the stroke. Weather or not that amounts to a hill of beans under dynamic conditions I could not tell you but it does seem odd they do it that way from the factory.
In order to keep more oil on the crank on mine I drilled smaller oil feed holes in the cam bearings as they are getting fed right off the oil going to the mains. When everything is done right in a SB oiling don't seem to be a big issue from what I have seen. I almost always use standard volume pumps and don't seem to have much issue getting enough pressure. The issue is the oil timing is wrong on these engines. You should have full oil pressure to the rods at 70* ATDC and that is IIRC but it is close to that. That's why a Chevy doesn't need full groove mains. The Chryslers get full oil pressure way before they need it so the full groove mains helps that. Seems to be worse on the SB but it is wrong on both. The higher the engine speed, the worse it gets. There are only two fixes for the high rpm stuff (unless you get a block that has the oil passage in the correct location). One is have a crank drilled with the oil hole turned counterclockwise. The other is more complicated. That is the only way I know to correct it.
[Re: mopar dave]
#2023029
03/02/16 06:07 AM
03/02/16 06:07 AM
Posts: 2,578 sweden
1Fast340
sweden
thanks. first time it happened to me. i think this was the 5th engine i put together and the first to explode. the number 8 piston looks like the pin was trying to come out the bottom. ill post some pics at the end of the week when i get it apart. Dont forget to look into this. Would not be surprised if your problems are related to this, rods dont try to pul a pin out of the piston without reason.
[Re: mopar dave]
#2023030
03/02/16 06:09 AM
03/02/16 06:09 AM
Posts: 1,361 Wild West
M_D
Wild West
Obviously it's important to have adequate oil delivery to bearings, and to have proper clearance which will vary depending on the engine and type of usage.
One thing that is often overlooked is the bore of the rod must be round, straight, and sized properly. It's about as important as round and true crank journals and round and straight cylinders. When the bearings are encapsulated in the assembled rod, if the bearing shells are not evenly and tightly contacting the rod bore they can walk around, and they also heat up significantly more because the poor contact between the bearings and rod doesn't transfer heat away from the bearing very well. The bearing shell is then prone to distort from excess heat and lack of support, which usually reduces the oil clearance, which is the beginning of the end.
That may not be what caused your problem, but it's very possible it was. If bearing to journal clearances are on the tight side that's 2 strikes. A lot of rods are honed with methods that are "iffy" and when not done correctly make the bearing bore bell-mouthed. I always inspect and measure the rod bores. On engines that have some run time on them you can look at the contact surfaces on the back of the bearing shells and the bores and see how well they fit.
[Re: mopar dave]
#2023037
03/02/16 06:43 AM
03/02/16 06:43 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Real sorry to see this Dave, i've put street stuff together but would rather have a motor done by a professional when it's going to see a lot of rpm and has high cost parts. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mopar dave]
#2023232
03/02/16 04:04 PM
03/02/16 04:04 PM
madscientist
Washington
I doubt that clearance was too tight, but I don't remember what oil you used. I am about ready to fire mine off and it has .0021 on the rods and .0024 on the mains. I'm going to use a 5w30 oil. If yours was too tight I'll be screwed just like you.
I think a lighter grade oil and FGM's and you will be ok.
[Re: madscientist]
#2023242
03/02/16 04:15 PM
03/02/16 04:15 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
joe gibbs xp4 15/50 non synthetic(breakin). like i said last 2 builds had .002 on rods and mains with full groove and using 20/50 amsoil, no issues. i had 100# oil pressure when first fired up, 75 when it got warm and 55 when it let go.
