Re: carnage at the dyno
[Re: mopar dave]
#2022201
02/29/16 11:10 PM
02/29/16 11:10 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Does the rod look "sawed off" where it hit the block, or just broken. With both rod bolts broken, my GUESS would be oiling issue or it just broke a rod bolt. Usually when one just breaks a rod, the big end stays on the crank.
Watching video, it didn't really sound to be laboring before it broke. So maybe it just broke a bolt. Even beat all to hell, the bearing should show an oil problem if there was one
[Re: mopar dave]
#2022223
02/29/16 11:36 PM
02/29/16 11:36 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Perhaps the crank was out of round? How do the other bearings look? What brand crank?
Be a good time to upgrade to a magnum block at the least.
[Re: Hot 340]
#2022232
02/29/16 11:46 PM
02/29/16 11:46 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
VERY sorry to hear this Dave.
[Re: mopar dave]
#2022238
02/29/16 11:54 PM
02/29/16 11:54 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
well today was dyno day and i thought it was going to be a great day, but it didnt turn out that way. engine came apart on the 5th short pull. only had 6000rpm on it at the time. not sure what caused it yet. still have to get it apart for examination. on #8 cylinder eagle H beam broke in the middle of the beam and both 8740 rod bolts are broke as well. looks like it took out 2 pistons the cam and the block. total pile of sh!t. also broke the pick up on the oil pump. looks like ill have to start over. it will be interesting to see what the cause was. Totally sucks, sorry to hear that.
[Re: mopar dave]
#2022245
03/01/16 12:01 AM
03/01/16 12:01 AM
Posts: 4,457 Washington
madscientist
Washington
I can't tell from the picks where it got the block. Did it take out a pan rail or something else I missed?
It's hard to say about the oiling and does number 8 get it first. It is technically a constant flow system so once there is pressure if the pump can keep they should all get oil all the time. My experience shows 3 and 4 are the first not to get oil but that is usually about 8000 RPM.
Bad deal for you for sure.
