Re: Fiberglass Cowl Hood For 64 Fury????
[Re: dOc …]
#202162
01/26/09 07:47 AM
01/26/09 07:47 AM
Posts: 299 Sparta, TN
mark42202
Sparta, TN
Well ...depending where the good-air is on your car .. the cowl scoop might work the best. What is your engine combo and speed of the car?
440 w/ iron heads and 850 on alky right now. Switching to a Dominator, which is why I need more clearance. As it sits right now, it runs 6.74@102 in the 1/8. After the changes I'm hopefully going to be seeing somewhere in the 6.20 range.
[Re: Greg]
#202165
01/31/09 09:49 PM
01/31/09 09:49 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
Well it didn't take you long to act on the tip about the hood. Nice meeting you Greg and hanging out at the Cook Shack.
Butch
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
[Re: mark42202]
#202167
02/01/09 02:52 AM
02/01/09 02:52 AM
Posts: 30,490 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
440 w/ iron heads and 850 on alky right now. Switching to a Dominator, which is why I need more clearance. As it sits right now, it runs [Email]6.74@102[/Email] in the 1/8. After the changes I'm hopefully going to be seeing somewhere in the 6.20 range.
So the intake/carb combo puts it through the hood ? .. how much ? .... A almost fail-safe hood and scoop combo is the 68 Hemi style.
I have to ask again ...do you know where the good-air is ? ... you can do that with a "powder-test" and then with a inches-of-water gauge.
