Page 4 of 4 1 2 3 4
Re: Cam choice for 505 to run 10.50's [Re: Sport440] #2007517
02/07/16 07:17 PM
02/07/16 07:17 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Tex [/quote]
I agree, if those were my only choices, I would run the smallest, the Howards cam.
But, what do you mean that all those cams were ground on a 104 Intake centerline.
Cams are grounds at A LSA and not at a Intake centerline. They are installed at a specific ICL
You stated differences of 110-108-106 LSA for the three separate cams. Im sure they weren't all ground on a 104 LSA Did , you mean a recommended installed 104 ICL
Also, I wouldnt use any of the cams you listed for what your doing. The hughes cam listed 6872 would be better IMO too.
[/quote]
Yes the Howards is 104ICL installed , all cams are installed 4 degrees advanced ICL over the lobe separation .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2007532
02/07/16 07:39 PM
02/07/16 07:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess I'll leave it with this......
Go to some of the on line dynamic compression calculators and see what those long duration cams and 10.5cr add up to...... And see if that number resonates in your mind as something that's going to make big power.
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2016106
02/20/16 03:46 PM
02/20/16 03:46 PM
Indianapolis
Roadrunner451 Offline
Indianapolis
I'll apologise for bringing this back up, but I find this a very interesting topic. I'm sure I'm not the only one as there are a lot of people in a similar situation. Having some people post with real world experience and have guys who do this sort of thing as a living has been pretty interesting. But there's a couple of things I was curious about.
Would it not make sense to run a bit more duration, but keep the lobe centers kind of on the tight side to keep the dynamic compression up ?
Run as much lift as you think you can tolerate ? I would think this would be up to the individual though.
Is more exhaust duration needed on a street/strip car even if it has a good exhaust system ?
Just some things I'm thinking about for my own car as well. I've had two reccomendations from two different cam grinders, and they are considerably different. The one I received had a lot of duration and a wide lobe center. Not really getting the wide lobe center thing at all.
Re: Cam choice for 505 to run 10.50's [Re: Roadrunner451] #2016326
02/20/16 10:51 PM
02/20/16 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would have to state what your gonna do with
the car and all the specs to the engine.. a wide
LSA will give a flatter torque curve but the narrow
one will give more bottom end torque... where do you
need it at.. if its a street/strip you might want the
wider LSA but advance the cam
wave
Re: Cam choice for 505 to run 10.50's [Re: Roadrunner451] #2016366
02/21/16 12:07 AM
02/21/16 12:07 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Roadrunner451 ,
Yes getting the most input can help . After running dynamic comp numbers like Fast said , it appears i will need to aim for around 60deg ABDC or less to gain/retain good compression . With my numbers there was nearly 1 point of compression between cam choices .As to tight lobe seperation i understand this to make the motor power peakier , wider is flatter/broader . Still waiting for my short so on hold .
Tex
New best MPH 130.32
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2016414
02/21/16 01:00 AM
02/21/16 01:00 AM
If you take the same solid lifter race lobes and grind two cams with different LSA only on a BB Mopar, and most other low rpm motors(peak HP below 7000 RPM)the one with the tighter LSA say 106 versus 110 or more the tighter LSA cam will out 60 ft the wider LSA and probally run as quick and as fast as the wider LSA on the other end twocents Wider LSA on race cams looses bottom end and gains top end, same thing on tighter LSA, more bottom end and looses high HP and RPM in each gear shruggy I like my motors to pull hard from the hit up to the shift points, even if it means shifting before 6000 RPM to make the car run the quickest it will run that cam and top end up twocents
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2016478
02/21/16 03:26 AM
02/21/16 03:26 AM
Indianapolis
Indianapolis
My combo is close enough to tex's that I'm not going to list it, and besides that would be bad form to steal his thread.
Anyway, I'm in the same boat as he is. I can't go much past 60deg abdc before the dynamic compression goes south. With that said, would it not make more sense to open the intake valve as early as possible, open it as fast and as far as is possible, and have it all done by 60 deg abdc or close to it ? This seems like a tight lobe center cam to me. Obviously we are operating under the constraint of a car that is driven on the street. Although for me it's a bit different, it's not my daily. I can push it a bit more.
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2016496
02/21/16 06:38 AM
02/21/16 06:38 AM
Australia
P
Project kickin A Offline
P
Australia
I run a 585 260@ 50 installed at 104 fast ramp Engle flat tap solid in a std RB 446 with sidewinder heads, hooker fender exits with a M1 and 1090 BG it went 10.55 last weekend, foot brake glide nothing too radical
Re: Cam choice for 505 to run 10.50's [Re: Project kickin A] #2016625
02/21/16 03:49 PM
02/21/16 03:49 PM
Is this cam ground on a 104 lobe seperation angle? If not what lobe seperation angles is it ground on and where do you have the intake lobe center installed at? confused
Re: Cam choice for 505 to run 10.50's [Re: Project kickin A] #2016645
02/21/16 04:24 PM
02/21/16 04:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
At what weight, gear & stall speed?
My old combo was 266 at .050" / .600" / 108 LSA + 4 SFT Comp grind from Porter Racing Heads, 452 RB w/ ported Stage VI heads (10.70 CR & 93-oct E10 fuel), BG 4150 carb, 2" headers & full exhaust, 4.10s & 4500-flash converter... ran 10.5s at 3750+ #s at near sea level tracks, and 2-3 tenths slower in summer heat and higher altitude tracks.
IMO, the OP doesn't need a "big" cam to run his posted #, just one that's a good fit for the rest of the combination. The Hughes 6872 on 108 LSA looks reasonable to me, too.
As always... just my opinion. shruggy
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2098370
06/26/16 08:24 AM
06/26/16 08:24 AM
Australia
P
P
Australia
2970lb 4.56s 4000
Page 4 of 4 1 2 3 4
