I used to run a M/T 13x31x15 Bias slick on my old racer on 10" wide Cragar Super Tricks. The new ride has these on 10x15 Centerline Warriors. If you run a wheel that is too narrow for a wide tire, you will need to lower the air pressure a lot to get the tire to make full contact at the line and then you won't have the stability you need at the top end
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
