Re: 72 challenger bumpers different from 73-74?
[Re: moparmatt]
#2015519
02/19/16 04:46 PM
02/19/16 04:46 PM
Posts: 4,321 St. Louis, Mo
318 Stroker
St. Louis, Mo
Ok so after yesterday I decided to put 70 challenger bumpers on my 73 , but my friend has a 72 since I have the 73 bumpers coming and i dont need them could my friend use them on his 72? thanks The physical shape of the bumpers are the same from 70-74. I believe there may be a difference in bolt-hole positioning on different years, which would be dictated by the holes in the brackets and what bracket is used. All of the brackets and all of the bumpers will bolt to the cars, but you need to compare bolt hole positioning with the bumpers he plans to use to see if they are compatible with each other.
[Re: moparmatt]
#2015634
02/19/16 07:44 PM
02/19/16 07:44 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Unless the bumper brackets were also changed. They don't swap We had a 74. Went to put 70 on it. Holes in the bumper are in wrong place
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: moparmatt]
#2015682
02/19/16 09:40 PM
02/19/16 09:40 PM
Posts: 3,378 KY USA
mopargem
KY USA
On the front 70-2 use a Y wishbone shaped bumper bracket. 73-4 uses a y one straight side with a fork bumper bracket and a heavy reinforcement plate. Bolt pattern different so use an earlier set of brackets. They make new ones AMD
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
