Re: Does anyone make an oversized thrust bearing for small block
[Re: Moparcars6874]
#2015125
02/19/16 12:51 AM
02/19/16 12:51 AM
RapidRobert
The MP oval track bible has a spec of .002"-.010" (crank end play)
[Re: Moparcars6874]
#2015504
02/19/16 04:22 PM
02/19/16 04:22 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Several different things can caused the thrust bearing to wear out, one is the converter being ballooned, another is not enough clearance on the converter to the flexplate to start with and possibly several others that I can't remember right now. The fix is to have the thrust surface welded and repaired or replace the crankshaft ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) We use to have a bad thrust surface hard chromed but a lot of that went away when the crazy enviormentalist got thier way with the local goverment agencys shutting the local chrome shops down ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
[Re: Twostick]
#2016413
02/21/16 12:59 AM
02/21/16 12:59 AM
RapidRobert
What is the endplay with a new thrust in it? Agreed, & I'd measure the flange thickness of the old/new #3 thrust bearing halves. As you know you'd want to do a thorough cleaning prep like you would on a regular rebuild. No thoughts/opinions on the cause. Holler what develops
[Re: Moparcars6874]
#2016525
02/21/16 11:18 AM
02/21/16 11:18 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
My 360 ate a thrust in 2014. I have not figured out why, no converter balloon, plenty of clearance from the flex plate etc. Mine was running great, I happened to notice the balancer moving while idling in the driveway one day. I never did measure how much it was out but it was ALOT I am surprised the belt stayed on.
I did what nobody should ever do in this situation because it was two weeks before drag week and I wasn't going to miss it. I bought a crankshaft kit from Orielly for $200 that came with a machined crank and bearings. I slapped that thing in and stuck it back in the car and put 1200 miles on it and raced it at 4 tracks in one week LOL. It has now done two drag weeks with that crank and has run a best of 11.16@119.5 MPH. I had pulled this motor out last summer but ended up havng to put it back in for drag week again due to problems with the other motor. We checked the thrust before we stuck it back in and it had .005 so I have no idea what happened to it before.
I have seen mention of a different thrust bearing for the earlier pre 76(i think) 360's but I have never confirmed this. When I bought the crankshaft kit for this motor I used a 1980 dodge truck to tell the parts store guy what I wanted. I have a 76 model block. Its possible I had the earlier thrust bearing in it before but I have never confirmed this, I have just seen it mentioned on here before.
68 Barracuda Formula S 340
[Re: Moparcars6874]
#2016532
02/21/16 11:39 AM
02/21/16 11:39 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Diameter of the thrust bearing flange is larger in the later setup.
Probably because the earlier design had a problem with thrust bearing wear.
Not sure you can run the later bearing in the early block, I know you can run the early bearing int he later block though.
[Re: Supercuda]
#2016596
02/21/16 02:19 PM
02/21/16 02:19 PM
RapidRobert
the block bearing saddle & cap the "recess" was enlarged in ~'74 to use the larger thrust flange #3 bearing (my 6-19-74 block is that) and hold your current bearing halves together like a clamshell and the OD for the later ones is a hair under 3" (2.91" comes to mind). I think your bearing just failed cuz stuff fails (tho I would for sure do the ballooning & other checks if you ain't already) & I hope with new bearings that the endplay is within specs. there might be a NAPA truck bearing with an even slightly larger OD (not sure) but I doubt if the flanges are thicker as unfortunately that would be a "problem solver" specific part. but there might be such an animal out there. holler how it goes EDIT the more I think about it the more I think there would not be such a part & (my) reasoning being is that the amt of wear on the crank could be anywhere so how additionally thick a bearing should a mfr make available (the crank would still have to be turned to get the clearance right). this is an infrequent occourance & likely the crank will have to be welded/turned or source another crank unfortunately
[Re: Bad340fish]
#2017173
02/22/16 03:58 AM
02/22/16 03:58 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
Back in '76 or so I bought a 383 powered '70 Cuda. The crank would move so far the motor would bog some at a certain rpm. What kept it from locking up I'll never know. Anyway, we pulled the motor, turned it upside down and put a new parts store crank kit in it. Put it back in the car and never had a problem with it. I drove it for a long time..hard, then sold it. The next owner never had a motor problem out of it either. I guess the oil filter took care of any metal in the motor.... Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
